Author Topic: Radiator  (Read 9747 times)
Radiator
« on: June 26 2020, 06:29:03 PM »
Getting ready for the track tomorrow and after the test drive my radiator sprung a leak. It's a pinhole leak up by where the upper hose comes out. Can these radiators be repaired would I be better off getting a replacement. If they can be replaced where is a good place to find a replacement. Better it happened here at home then after a 2-hour drive to the track but still a pain in the ass.
Re: Radiator
« Reply #1 on: June 26 2020, 08:32:03 PM »
If you can find a radiator shop they can be repaired. At this age, i would replace it
Re: Radiator
« Reply #2 on: June 26 2020, 08:37:36 PM »
I can get a replacement from rock auto for 165. An aluminum one from OPGI for 245 or another aluminum one from g body for 459....recomen dations?? I don't know anything about radiators
Re: Radiator
« Reply #3 on: June 26 2020, 09:17:01 PM »
Cheapass Camaro rad and trans cooler.
Offline Tim Hensley
Re: Radiator
« Reply #4 on: June 27 2020, 02:22:59 AM »
Spectra radiator CU162 is very similar to the Camaro but it’s inlet and outlet same size and location as OEM
DLS 210-210
Champion irons
Re: Radiator
« Reply #5 on: June 27 2020, 08:11:35 AM »
Getting an all aluminum one from rock auto, 200 with new hoses
Re: Radiator
« Reply #6 on: July 02 2020, 10:14:16 AM »
New radiator is coming in today old radiator has tranny cooler built into the radiator and then there's an aftermarket cooler strapped to the front of it for engine oil new radiator has Provisions it appears that I can put the engine oil through the new radiator and the same connections for the tranny oil. Should I retain the engine oil cooler or plumb into the new radiator....wh ich would cool better
Re: Radiator
« Reply #7 on: July 02 2020, 10:55:05 AM »
Not sure I understand what the new radiator comes with, but, if it has both coolers in it, I would route the transmission oil thru the cooler in the radiator, on to the external cooler in front of the radiator and then back to the transmission.
The line coming from the transmission would go to the lower fitting on the tranny cooler in the radiator, then the top fitting would go to the lower fitting on the external cooler, and the top fitting back to the transmission.  I think this will best push out or eliminate trapped air in both coolers.
« Last Edit: July 02 2020, 11:15:58 AM by Steve Wood »
Re: Radiator
« Reply #8 on: July 02 2020, 06:17:28 PM »
Thanks for the info I get what you're saying. I attached a picture do I leave the black plastic plug in there or should I replace that with a metal one?
Re: Radiator
« Reply #9 on: July 02 2020, 10:52:18 PM »
I assume the black plugs are to close off one of the coolers if you don't use it?
You are going to use both the transmission cooler and the engine oil cooler as I understand it.  So you would remove the appropriate plugs and replace them with fittings that fit your oil cooler lines or transmission lines.
Your transmission line from the tranny will go to the lower fitting on the radiator.  then the top fitting for that cooler goes to the lower fitting of the external cooler.  And the top fitting of the external cooler will connect to the return line going back to the tranny.
Obviously, we have to use some rubber line to go from the radiator cooler outlet line to the external cooler and from the external cooler outlet to the return transmission line.
(Unless you like to go to the effort to use steel braided hose or the push loc type hoses.
Re: Radiator
« Reply #10 on: July 02 2020, 10:53:36 PM »
BTW, a lot of us don't use the engine oil cooler at all.  We just remove the adapter plate behind the filter and do without....
Re: Radiator
« Reply #11 on: July 02 2020, 11:57:01 PM »
Thanks Steve!
Re: Radiator
« Reply #12 on: July 04 2020, 09:06:04 PM »
The lower coolant outlet came with a rubber sleeve on it, upper one didn't, do I leave it on or remove it???
Re: Radiator
« Reply #13 on: July 04 2020, 09:49:32 PM »
I am sure you need to remove it
Re: Radiator
« Reply #14 on: July 06 2020, 06:17:46 PM »
Well I got the radiator swapped in. No leaks, it's a miracle!! took it out for a test drive it's hotter than hell here today before when I ran the air conditioning the temp always climbed up to about 185 but now she stayed right at 160. Very pleased :rock:
