Author Topic: Translator  (Read 4564 times)
Re: Translator
« Reply #15 on: June 28 2020, 05:06:48 PM »
Quote from: "Steve Wood"
I normally leave the translator settings on the defaults and sort out any fueling with the chip.
Same.   I've done back to back tests where I've made a change with the Translator, then did the exact same change with the chip.
The chip adjustment give me the desired results, and the Translator gave me problems.
If it can't be fixed in the chip, you need a new chip.
