Author Topic: Is Earl still making front covers?  (Read 37595 times)
Re: Is Earl still making front covers?
« Reply #30 on: June 28 2020, 10:19:05 AM »
Hey Earl, whats the actual plan for this cool beast? Driving in circles somewhere?
« Reply #31 on: June 28 2020, 10:50:55 AM »
Oh god no.   'Racing' around in a circle makes as much sense and thinking a dog can win chasing its tail.
I'm going to put it on the street and clean out all the slim trailer park girls.   The prepnecks in their jacked up trucks on 20's (that's never seen mud) will be pissed.
I got a 3v mod engine in it now and GOOD GOD those stupid things are huge! I got it so high it almost hits the hood (removed the 'factory' air filter/ ram air box) and the pan still hangs 3" below the 'crossmember'.   Which is bad because the frame is only a few inches off the ground at rest.    And the front frame brace won't fit no matter what.
...and I've just about convinced myself to build a 351 for it and sell the Mustang engine/trans.
Offline Tim Hensley
« Reply #32 on: June 28 2020, 12:44:29 PM »
So cool I vote 351. You going to put it on the street? My uncle had a 60 or 61 Pontiac numbers and all he drove on the street. It was a blast climbing in the window.
DLS 210-210
Champion irons
Offline Tim Hensley
« Reply #33 on: June 28 2020, 12:49:57 PM »
Whoops got sidetracked forgot why I cam here.
I just got a 87 turbo engine with about 50 k. Should I stash the front cover away it looks good.
DLS 210-210
Champion irons
« Reply #34 on: June 28 2020, 03:43:20 PM »
Yes
« Reply #35 on: June 28 2020, 05:02:02 PM »
Quote from: Tim Hensley
The problem isn't the engine so much as the transmission.   The cost to put a strong manual behind a conventional engine is damn near (or possibly) more than I paid for the car.
   The reason I went with the mod motor was the modern trannys (not to be confused with Bruce Jenner).   If they would have used a SBC bell housing pattern on the mods, it's would already be running.    But what I've learned about Ford and how they do thing with their wiring, computer boxes, tunes, anti-theft, and whatknot..    I would have sucked it up and spent a fortune or just bought a weak ass T5.
   I've got a bunch of 460's I scored a year ago, but I don't think I can put that much weight on the front and sleep at night.
  It would be nice if I knew what each corner actually weighed minus all the ballast and shit.
« Reply #36 on: June 28 2020, 05:02:32 PM »
Packrat all the parts that aren't made anymore.
(sorta like all my NOS covers)
« Reply #37 on: June 28 2020, 06:39:04 PM »
Earl look at QuickTime bellhousings - they aren’t cheap but they have adapters for putting the Chevy style manuals behind ferds.
Something like https://www.holley.com/products/drivetrain/bellhousings/ford/parts/RM-6066
