that one is 28 1/8" long apparently.
ATP Y211 is also listed. It is 22 3/4".
I/m not sure exactly how they measure but I would guess the total length of the inside cable part.
You can measure from the end on the throttle body to the firewall and then measure from the inside firewall to the gas pedal end--then add the two measurements and see which it comes the closest to. You can be a bit long, but you cannot be too short
