Author Topic: FEL-PRO Transmission Pan Gasket  (Read 8532 times)
Offline gnonyx
« on: February 24 2020, 08:08:04 PM »
Can I apply silicone on pan for this Fel-Pro gasket, or install it dry?
Re: FEL-PRO Transmission Pan Gasket
« Reply #1 on: February 24 2020, 11:31:54 PM »
I have always installed them dry.  If I were using silicone, I would glue the gasket to the transmission instead of the pan.
Offline gnonyx
« Reply #2 on: February 25 2020, 08:42:53 AM »
Do you used the same gasket type, and if not what brand?
« Reply #3 on: February 25 2020, 09:04:16 AM »
The gasket you have is fine. No sealer.
« Reply #4 on: February 25 2020, 09:22:18 AM »
Not much choice in gaskets for the transmission. Felpro is what I have used.  One of these days I will change mine again.  They tend to start leaking when the car is not driven much-just like all the other gaskets :D
72-120 lb-inches of torque.  I think I used to set my wrench to 100 lb-inches
« Last Edit: February 25 2020, 09:41:48 AM by Steve Wood »
