Author Topic: Gas pedal cable replacement  (Read 3410 times)
Offline gnonyx
« on: February 24 2020, 10:05:36 AM »
Is it wise to replace the original gas pedal cable, or just leave along since it's still function?
Re: Gas pedal cable replacement
« Reply #1 on: February 24 2020, 04:21:55 PM »
I think one of mine broke many years ago.  The other one was stretched and I fixed it with a tie wrap in order to get full throttle movement as shown on my site.
It would not hurt to have one on hand, in case the original breaks, and it should be easy to fix so it would not hurt to replace it if you just need something to do....or believe in preventative maintenance, :D
Offline gnonyx
« Reply #2 on: February 24 2020, 05:34:53 PM »
Like you said, I will probably get one just in case the original breaks.
The only problem of replacement I would have to check and maybe readjust the TV cable, TPS and WOT again
