Author Topic: EGR Block Off Plate  (Read 5243 times)
Offline gnonyx
EGR Block Off Plate
« on: February 19 2020, 07:22:00 PM »
Hi All,
Question, When ordering this EHR block off plate, why are they sending a screw when the original set up is bolted down with a nut?  Or is every engine has a different factory set up?
My personal feelings, Forget about the useless screw just send a gasket.
Re: EGR Block Off Plate
« Reply #1 on: February 19 2020, 08:19:05 PM »
Vid from my channel shows a fancy ass bolt. I prolly removed the threaded bolt...just can't remember doing it.
https://www.youtube.com/watch?v=LxmIjsS4Ujc
Offline gnonyx
« Reply #2 on: February 19 2020, 08:22:00 PM »
Is it necessary to remove the threaded bolt? Why not use the nut?
« Reply #3 on: February 20 2020, 12:44:11 AM »
Doesn't really matter either way.   Those block off plates (AKA 'reeds') are nothing more than POS's.
« Reply #4 on: February 20 2020, 09:24:12 AM »
With the correct gasket and sealer they work mint.
« Reply #5 on: February 20 2020, 10:43:30 AM »
Yep, glued one down on the GN 20 years ago and it has been good so far. I have seen others that leaked on other cars. Must be the prep
Offline 278CIKILLER
« Reply #6 on: February 21 2020, 11:26:11 AM »
I have two brand new ones for the EGR and throttle body, $50 ship.
Offline gnonyx
« Reply #7 on: February 22 2020, 08:16:00 PM »
Do you high temp rtv on both sides of gasket or just the side of the EGR plate?
« Reply #8 on: February 22 2020, 09:03:42 PM »
I'm sure it is on both sides
Offline gnonyx
« Reply #9 on: February 22 2020, 10:40:27 PM »
Thanks, I wasn't sure if it was one side or both.
Today I drain the tranny fluid and it's a lot of fluid since it has a deep pan cover.
Tomorrow I will check the TV cable setting with the valve body plunger, I will post some pictures or video of making the GM style adjustment, and compare to see how close the plunger valve is at full wot
