Author Topic: Donut between downpipe and elbow  (Read 8225 times)
Offline gnonyx
« on: February 15 2020, 12:50:59 PM »
Is there another donut that would be an oversize compare to the normal size stock?
 After tuning and adjustment was made I did notice some exhaust was expelling around the donut area.
 The donut was replaced and the stock bolts with spring are max out
Offline Grumpy
Re: Donut between downpipe and elbow
« Reply #1 on: February 15 2020, 01:03:52 PM »
did you use both pieces ??  :chin:
Offline gnonyx
« Reply #2 on: February 15 2020, 01:06:25 PM »
What do you mean by both pieces?
Offline reality
« Reply #3 on: February 15 2020, 05:48:03 PM »
THE pipe is fubared. You might try hammering the flange closed or put a sleeve in.
Offline gnonyx
« Reply #4 on: February 15 2020, 05:58:39 PM »
Can you define sleeve in
Offline reality
« Reply #5 on: February 15 2020, 06:29:13 PM »
If I said shim the flange would that help? The pipe under the gasket is ''stretched''.
« Reply #6 on: February 15 2020, 06:43:45 PM »
Did you loosen the 4 bolt flange that connects to the y-pipe before you tightened the bolts to the turbo elbow? Make sure to support downpipe with jack stand or jack. Both with make it easier to line up properly and take all the weight/tension off the flange while you snug everything back up.
Offline gnonyx
« Reply #7 on: February 15 2020, 06:52:18 PM »
shim I understand
Dump question, but how does a steel pipe flange gets stretched when it's only to tighten a donut against an exhaust elbow?
Offline gnonyx
« Reply #8 on: February 15 2020, 07:02:23 PM »
I'm not familiarize with the 4 bolt flange that connects to the y-pipe since all was good until I replaced the intermediate pipes and mufflers. I didn't disconnected the flange donut connection while doing the muffler replacement, but then realized the downpipe was loose from all the movement of putting the muffler back together again. I place a jack underneath the hollow converter, and replaced the donut with a new one. Jack the converter upward enough to start the downpipe flange bolts.
Offline Grumpy
« Reply #9 on: February 16 2020, 09:48:01 AM »
Ill get a pic later today.
Offline gnonyx
« Reply #10 on: February 16 2020, 11:48:40 AM »
Okay Thanks
Offline Grumpy
« Reply #11 on: February 16 2020, 03:27:23 PM »
here ya go
Offline gnonyx
« Reply #12 on: February 16 2020, 03:56:10 PM »
here ya go
I appreciate the photo of an exhaust donut, but I can't read the number, can you please post the number
Thanks
Offline Grumpy
« Reply #13 on: February 17 2020, 05:29:28 AM »
i posted it so you can see the piece that goes inside the donut. i doubt the part # will do any good .. its prob 25 years old. sorry the damm pics were so big.
« Reply #14 on: February 17 2020, 10:05:48 AM »
I don't know if this is both parts, or not    https://www.highwaystars.net/gasket-turbo-exhaust-downpipe-gm-1262500/
Autozone and others sell the Walker donut replacement.
When I had a stock dp, I used to put a thin coat of high temp copper rtv on it before bolting it down
