Author Topic: Vacuum Master Cylinder  (Read 7735 times)
Offline john robertson
  • I'M INCOGNITO
Re: Vacuum Master Cylinder
« Reply #15 on: February 10 2020, 08:21:02 AM »
The picture you submitted shows that the front fitting is larger than the rear fitting as they are on all G-body master cylinders. You can't reverse them.
THIS IS CORRECT!
Offline gnonyx
« Reply #16 on: February 10 2020, 07:41:02 PM »
THIS IS CORRECT!
Yes I know, as I already tired to see if it could be switch, and it can't
Thanks
