Author Topic: Best oil pump pick up tube for 109  (Read 4410 times)
Offline 1KWIKSIX
« on: January 04 2020, 09:28:24 AM »
Am looking for a replacement oil pump pick up tube / screen ass’y for 109 short block.
What’s the recommendation?
* original GM used pick up tube?
* melling pick up tube?
* TA Performance pick up tube?
http://www.taperformance.com/proddetail.asp?prod=TA%5F1520D
Re: Best oil pump pick up tube for 109
« Reply #1 on: January 04 2020, 10:04:08 AM »
How many times do I have to say stock junk rules. I only made about 4 million passes with stock junk with zero issues.
Offline 1KWIKSIX
« Reply #2 on: January 04 2020, 10:47:19 AM »
Ok, would anyone have a nice clean factory oil pick up tube in good condition available?
« Reply #3 on: January 04 2020, 01:40:22 PM »
If you cannot find a clean stock pick up tube, I would say either Melling or TA would be fine.  What ever you can find that costs the least to deliver.  The Melling is $17 from Rock, but, you may find something local that costs less.  I don't believe there is anything magic about them
« Reply #4 on: January 04 2020, 05:01:58 PM »
I may have one. Text you if I do.
Offline ss/gn
« Reply #5 on: January 04 2020, 06:37:24 PM »
Not sure I would go with a used pick up when new is available. Either will work
https://www.summitracing.com/parts/slp-224-128/overview/
https://www.summitracing.com/parts/mel-20is2/overview/
Kevin
Offline 1KWIKSIX
« Reply #6 on: January 04 2020, 08:14:50 PM »
Thanks Gents! :023:
« Reply #7 on: January 05 2020, 09:06:11 PM »
Mellings have higher flowing mesh and no trap door to dump contaminates all at once.
Offline 1KWIKSIX
« Reply #8 on: January 07 2020, 08:02:23 AM »
Got a Mellings unit on order.
Thanks to all. :023:
Offline Langston
  • Newbie
« Reply #9 on: January 08 2020, 09:04:39 AM »
How bad is that in reality?
« Reply #10 on: January 08 2020, 10:10:26 PM »
The trap door can let large chunk go around the screen.
That's not good for oil pumps, turbos, and bearings.
