Author Topic: rebuilding my turbo  (Read 4378 times)
Offline reality
rebuilding my turbo
« on: December 23 2019, 06:26:56 PM »
Image may contain: outdoor
Re: rebuilding my turbo
« Reply #1 on: December 27 2019, 01:33:09 PM »
Is it an actual turbo or a centrifugal pump?  And yes, I know a turbo is a centrifugal pump but the volute is a little bit different.  And this thing has variable inlet vanes.
Offline reality
« Reply #2 on: December 27 2019, 03:07:06 PM »
« Last Edit: December 27 2019, 03:11:17 PM by reality »
Offline bullnerd
« Reply #3 on: December 27 2019, 06:36:27 PM »
Did you have to change your converter when you put that in?
« Reply #4 on: December 29 2019, 09:15:33 AM »
I had to search for:"A "Voith" spiral turbine (9000 hp ) built in Germany for a powerplant in Norway. Taken in 1931."  Used to make hydro-power up to 6 MW.
« Reply #5 on: December 31 2019, 02:09:07 PM »
That makes more sense and explains everything!
