Author Topic: Window motor circuit breaker  (Read 8000 times)
« on: November 20 2019, 04:23:49 PM »
What is it's function? Is that the component that cuts current to the motor once it reaches the end of travel? If I want to increase the voltage and current to the motor to speed them up, would I have to use a higher value breaker?
Re: Window motor circuit breaker
« Reply #1 on: November 20 2019, 05:08:21 PM »
I would be interested to know if it actually trips. 30A isn't it? The current should go up whey you stall but maybe the motor design limits the current somehow. You may not draw significantly more current with a higher voltage. I'm guessing the windoturboenca bulator has its own protection or do you stick the breaker into the unit?
« Reply #2 on: November 20 2019, 07:10:27 PM »
I seem to remember there's a temperature circuit breaker inside the motor.. I need to do some more research.
« Reply #3 on: November 20 2019, 07:18:07 PM »
Bimetal is cheap so most likely
« Reply #4 on: November 20 2019, 07:29:44 PM »
There is a thermal switch in the window motor itself - I assume that's what stops the power once the windows reach the end of their travel. Couldn't find a schematic, but it's shown in this video.
https://www.youtube.com/watch?v=PoVAdBW66Xg
« Reply #5 on: November 20 2019, 10:46:46 PM »
IIRC Gary K published bypassing that contact set and put a fuse in series instead, claimed it worked better . maybe those contacts degrade?
« Reply #6 on: November 21 2019, 08:13:20 AM »
I think it's voltage drop to the motors that causes the issue, and a poor design. Seems the fix is more power,  but  the modules available to fix it are way too expensive for what they are. They sell for $149+, I can build a nice one for ~$35.00.
« Reply #7 on: November 21 2019, 11:32:00 AM »
Are you looking at the manual?
« Reply #8 on: November 21 2019, 11:50:39 AM »
I went down the same path a while ago, bought some boost converter to try but that project has not floated up to the top of my pile.
« Reply #9 on: November 21 2019, 01:25:37 PM »
The circuit breaker in the fuse panel is just a "fuse".  It also powers the sun roof.
Each window motor also has a breaker in it in case a window gets stuck or tries to keep running once open or closed.
The Pink wire supplies power to the switches and I think this is where "low Power" problems occur.  One could run power straight from the battery via a relay and trigger it with the pink wire coming from the fuse panel breaker.  The out power side of the relay would go to the switches where the pink wire attaches.  That is my thought after looking at the diagram.
If one could boost the power a volt or two from the battery or alternator, that would be even better.
« Reply #10 on: November 21 2019, 02:39:52 PM »
AFAIK the windoturboenca bulator  just inserts into the breaker's position thus having a 12v supply for itself and connection to the downstream motors. and you add a good ground, A step up switching supply guessing 19-24V, maybe with some build in current limiting to protect itself.
« Last Edit: November 21 2019, 02:47:50 PM by daveismissing »
« Reply #11 on: November 21 2019, 02:51:14 PM »
The "Windowracer" is just a DC > DC booster, from what I have read the motors can take up to 20v and a few more amps. That's all it is, but a very expensive one. I already have  an 8 or 10ga wire running into the car , I will back feed the circuit breaker and see if it helps. If not, I will make my own booster and share the info.
« Reply #12 on: November 21 2019, 03:20:17 PM »
The asian specs are so exaggerated -best just buy one of the biggest ones
« Reply #13 on: November 21 2019, 04:54:12 PM »
There's units that output 10A, way more than enough, for ~$17 or so...
« Reply #14 on: November 21 2019, 07:24:30 PM »
I think the 30A breaker suggests it should be rated more than 10A - and is that a real 10A
