Author Topic: Building A Garage  (Read 30682 times)
Re: Building A Garage
« Reply #75 on: June 15 2020, 09:18:16 PM »
How many feet from the property line? A lean roof ...after final inspection. Eventually closed in then becomes part of the garage.
« Reply #76 on: June 15 2020, 10:07:30 PM »
Garage has to be a minimum of 6 feet from the house. The current garage is 3 feet off the neighbours property line. We're leaving it at that.
« Reply #77 on: August 01 2020, 09:26:03 AM »
Garage is well on the way to being built. I've shot vids of each step of the way. Will be posting them when edited.
Offline Tim Hensley
« Reply #78 on: August 02 2020, 01:35:38 AM »
Thanks for keeping use up to date
DLS 210-210
Champion irons
« Reply #79 on: August 02 2020, 10:25:39 AM »
Here is a preview
« Reply #80 on: August 02 2020, 01:24:38 PM »
Jeremy, there's a foot of crushed limestone compacted and a foot of concrete for the floor. The concrete is still hot from curing.
« Reply #81 on: August 02 2020, 02:33:57 PM »
That’s a lot of concrete!
« Reply #82 on: August 02 2020, 05:31:01 PM »
First vid. Garage demolition.
https://www.youtube.com/watch?v=rVUdLudHfKo
« Reply #83 on: August 02 2020, 06:56:16 PM »
« Reply #84 on: August 02 2020, 07:44:57 PM »
« Reply #85 on: August 02 2020, 07:59:12 PM »
« Reply #86 on: August 03 2020, 11:45:45 AM »
why such a thick slab?
« Reply #87 on: August 03 2020, 12:04:31 PM »
Overkill on the slab is a good thing.
Offline 1KWIKSIX
« Reply #88 on: August 03 2020, 12:49:43 PM »
Garage is Looking good Brad 👍
30 MPA concrete and a lil rebar strategically placed for a lift?
« Reply #89 on: August 03 2020, 04:12:28 PM »
No lift.
