Author Topic: Exhaust Y Pipe  (Read 7028 times)
Offline gnonyx
Exhaust Y Pipe
« on: October 21 2019, 09:04:46 PM »
Hi, Looking for an 87' GN Exhaust Y Pipe
Picture and price if possible, Thanks, Julio
Re: Exhaust Y Pipe
« Reply #1 on: October 21 2019, 09:06:54 PM »
Kirbans don't fit. Been there...done that.
Re: Exhaust Y Pipe
« Reply #2 on: October 22 2019, 12:44:27 PM »
walker?
« Last Edit: October 22 2019, 12:52:58 PM by daveismissing »
Re: Exhaust Y Pipe
« Reply #3 on: October 22 2019, 12:53:32 PM »
Hmmm no Y pipe or cat
Re: Exhaust Y Pipe
« Reply #4 on: October 22 2019, 03:10:47 PM »
http://buickgn.com/CatBack.htm
3" stainless setup.
I'm told pypes makes a 2.5" system that is pretty nice.
What happened that you only need the y pipe?
Re: Exhaust Y Pipe
« Reply #5 on: October 22 2019, 04:52:55 PM »
Put a Hooker setup on my GN when I first got it. Cheap...but it fit and had correct turbo mufflers with it.
Offline gnonyx
Re: Exhaust Y Pipe
« Reply #6 on: October 24 2019, 09:46:38 PM »
Hi, Just letting your know I went to the muffler shop to cut and weld a new offset section of both pipes and they did a good job.
 Now I'm fighting with putting everything together which is not easy doing it by yourself. Today I finally got all together except for both tail pipes which needs to be extended since I cut off close to the factory weld, buy still needs the extension.
 Thanks for your help, Julio
Re: Exhaust Y Pipe
« Reply #7 on: October 24 2019, 10:28:42 PM »
Looks good. Laying on your back under these cars sucks.
Offline gnonyx
Re: Exhaust Y Pipe
« Reply #8 on: October 25 2019, 04:48:45 PM »
It may look by a tuff job doing it by myself, but nothing can compare to when I had to replace the transmission by myself.
 I jacked the car as high is it can go, but still I had to till the tranny downward to clear the tranny's bell housing. Then while underneath is went I installed the torque converter.
 The only good thing I did was given my wife a set of sound proof headset, of not to head me on my moments of few words. :013:
 The only thing I have to do is go back to the muffler shop so they can weld an extension pipe to the tail pipe. Once I finalize all I will post to you again (if possible being underneath) some pictures of the complete exhaust system.
Offline 278CIKILLER
Re: Exhaust Y Pipe
« Reply #9 on: October 25 2019, 05:28:58 PM »
Trannys walk in the park, 1 hour and it's out, back in takes 1 1/2 hour..
Offline gnonyx
Re: Exhaust Y Pipe
« Reply #10 on: October 25 2019, 09:19:56 PM »
Interesting, At what age did you do the tranny thing?
Did you have a lift, or just use floor jack?
Offline 278CIKILLER
Re: Exhaust Y Pipe
« Reply #11 on: October 25 2019, 09:50:50 PM »
i'm pushing 60. be doing them for 30 years, floor jack.
Offline gnonyx
Re: Exhaust Y Pipe
« Reply #12 on: October 26 2019, 08:46:39 PM »
Good to hear, I'm 67 and the only time I did tranny work is when I was young working with my mechanic father doing a 1960 Cadillac tranny on the driveway in the winter. I learned from him, and today I thank my old man for teaching me a lot of mechanical stuffs, as this save me a lot of money, and knowing I'm doing the work correctly.
