Author Topic: Power Logger aux inputs  (Read 3485 times)
« on: October 02 2019, 07:47:22 PM »
Finally wiring these things up-questions:
The only sensor you can use with power logger is a 100psi sensor?
Does PL assume 5V or 4.5V at 100psi?
Does the above hold constant when you apply an offset in the settings?
What is the difference in 100psi-B vs 100psi in the settings?
No way to put ANA4 or 5  in the Gauge page?
Re: Power Logger aux inputs
« Reply #1 on: October 02 2019, 09:02:10 PM »
This is the sensor Eric recommends...1 00PSI.
https://www.summitracing.com/parts/avm-30-2130-100
« Reply #2 on: October 02 2019, 09:23:20 PM »
Which suggests 0.5-4.5volts is the range:
« Reply #3 on: October 02 2019, 09:55:10 PM »
I spent some time sifting through Erics forum...but the particular question didn't come up.
« Reply #4 on: October 02 2019, 10:29:09 PM »
You can use any sending unit you want that has variable voltage (not variable ohms).
Then edit the .ini file to reflect the display numbers relative to the input voltage.
« Reply #5 on: October 02 2019, 10:56:55 PM »
Quote from: earlbrown
Excellent, that was what I needed. I am re purposing some industrial AST 4-20ma sensors so tweaking in the .ini is easier than resistor fiddling.
(You possibly could use an ohmic sensor- as long as you can create an appropriate voltage divider)
« Reply #6 on: October 02 2019, 11:51:46 PM »
IN the past, I never heard much good about the AM sensors.  I have used these with good success  http://www.motorsportsinnovations.com/wide_band_o2_files/WB_Pressure.htm
« Reply #7 on: October 03 2019, 08:56:58 AM »
Quote from: Steve Wood
AST- American Sensor Technology, same mfg as mine. Believe Bison is a big fan.
 Going to be harder to keep track of now that TYCO-TE have bought them
« Reply #8 on: October 03 2019, 09:54:30 AM »
Dave, I talked to Scoob. He's gonna tune your wifes car to go faster than yours. He can be bribed with Scooby snacks tho. Sugarless of course!
