Author Topic: factory tach/boost unit  (Read 6369 times)
Offline channer
Re: factory tach/boost unit
« Reply #15 on: September 30 2019, 08:29:40 PM »
I have one of Eric's chip, 50lb injectors and a upgrade fuel pump.
I checked with my friend that built the motor many years back!!! he did say the motor need to come out... so I really doubt if the head stud has the allen key end.
I have figured if it is bad head gasket or something else.  for the last 2 years when I bring the car out from storage, I notice water in the pan... so I drain the pan, put in new oil & GM's rad pill/leak fix.   I let it run for a while and drain the pan.  The first change over, the oil looks like chocolate milk.  I do this a couple of time until the oil looks like oil.    I have done 2 oil change since... and no sign of antifreeze or leak.  I guess those GM rad pills for... for a season.
I guess over the winter, the antifreeze slowly leaks into the motor.  I hope it is head gasket... but I fear the worse.. like a crack block or something.  Unfortunately, I don't have garage space to do work!!!!
And now for my next dilemma, my 2009 GMC Sierra is in for a motor rebuild.  I thought is was the dreaded bad lifters... but the dealership said something happen to the bottom end.... that is $8000.
dave
« Reply #16 on: September 30 2019, 08:46:40 PM »
Block will be fine as long as your antifreeze is up to snuff. Hit the wreckers for another engine for the truck. It'll be the cheaper way out.
« Reply #17 on: September 30 2019, 08:49:53 PM »
Garage space...what's that. I do it right in the driveway. My neighbours love me. Yamaha receiver blasting the tunes...air compressor running...beer drinking...swe aring. Oh hell yeah!!!
