Author Topic: 6.25 translator and 3.5 LS1 Sensor  (Read 3440 times)
Offline gnonyx
« on: September 23 2019, 05:42:56 PM »
Hi Looking for a good 6.25 translator and a 3.5 LS1 Sensor with a decent price to sell
Thanks
Re: 6.25 translator and 3.5 LS1 Sensor
« Reply #1 on: September 23 2019, 06:56:18 PM »
I've got a tested good 3.5" sensor for $80 shipped (in the lower 48)
Offline gnonyx
« Reply #2 on: September 25 2019, 07:53:52 AM »
Just letting you know I already got a new Delphi AF10056 MAF
In the future I will get the translator as well
Thanks
« Reply #3 on: September 28 2019, 10:02:50 AM »
When you're ready...order your Translator from Eric. FT's service isn't what it use to be.
