Nasty Wendy Isn't
valve covers
Topic: valve covers (Read 4913 times)
daveismissing
valve covers
September 03 2019, 07:44:34 AM »
So Cruz appears to have a teflon rocker gasket.I don't recall seeing many teflon gaskets generally and IIRC a property of teflon is that it creeps,IE: deforms over time.I wonder how these will hold up.
Tim Hensley
Turbo Street Modified
Boost n00b
Re: valve covers
September 04 2019, 02:51:22 AM »
We use Teflon gasket on everything in the power plant, up to 600 degrees,but it’s a onetime use only.
I’ve seen a lazy person open a door do what needed to be done and close it and not leak.
Good stuff
DLS 210-210
Champion irons
daveismissing
Re: valve covers
September 04 2019, 07:51:49 AM »
Thanks Tim, Good to know there is a track record, The one time use makes sense to me. Silicone and Teflon are good to high temperatures, I would not have questioned silicone as a gasket material.
I have worked with some crazy aircraft wiring where the insulation is 3 layers -teflon-kapton-teflon, either one would have to be too thick and heavy to be sufficiently durable on their own.
Tim Hensley
Boost n00b
Re: valve covers
September 05 2019, 03:38:24 AM »
I went to Cruz website could not find that gasket for the price,but I want a set.I don’t have a leak after 3000 miles but it’s gonna leak someday. Just hope not this Sunday.
Just wish the girlfriend side wasn’t so hard to remove.
DLS 210-210
Champion irons
earlbrown
PSI: 6
Re: valve covers
September 05 2019, 01:32:52 PM »
Did plain ole inexpensive cork stop working recently?
Tim Hensley
Boost n00b
Re: valve covers
Reply #5 on:
September 05 2019, 02:28:02 PM »
Yes my cork is working only needed tightened twice seconds time all good
I think I like spending money needlessly sometimes. Need to work on that bad habit
DLS 210-210
Champion irons
earlbrown
PSI: 6
Re: valve covers
Reply #6 on:
September 05 2019, 05:51:44 PM »
In that case, you don't need fancy schmancy valve cover gaskets, you need an aftermarket ECM
Re: valve covers
Reply #7 on:
September 05 2019, 05:59:31 PM »
I knew we had a lot in common...spend
ing money unnecessarily
Tim Hensley
Boost n00b
Re: valve covers
Reply #8 on:
September 05 2019, 11:55:59 PM »
Earl pulling the girlfriend side valve cover off is pushing my skill level
Aftermarket ECU will be pushing me over the edge
DLS 210-210
Champion irons
earlbrown
PSI: 6
Re: valve covers
Reply #9 on:
September 06 2019, 12:21:41 AM »
When the sin'n'piss side doesn't want to act right....
....go inside, drink a beer, then walk back to the car.
It'll pop right off.
(it doesn't hurt if you bump the starter a little a little so the rearmost rockers move around a little)
daveismissing
Re: valve covers
Reply #10 on:
September 06 2019, 11:34:43 AM »
You should open a shop Earl- you wouldn't make as much money as the other guys milking us but you would have a loooong list of customers.
earlbrown
PSI: 6
Re: valve covers
Reply #11 on:
September 06 2019, 01:13:35 PM »
Oh, god no. You have no idea how many times I have to say ''I don't work on cars''.
Tim Hensley
Boost n00b
Re: valve covers
Reply #12 on:
September 06 2019, 02:13:26 PM »
Is light beer ok
I tell my friends the same thing NO ,my wife is waiting for me to finish her truck.
I’ve bought her 3 new vehicle since I started
DLS 210-210
Champion irons
earlbrown
PSI: 6
Re: valve covers
Reply #13 on:
September 07 2019, 02:25:49 AM »
Lite beers is what I run on.
Scoobum
Re: valve covers
Reply #14 on:
September 07 2019, 09:10:46 AM »
The Right Stuff
valve covers
