Author Topic: floor pan  (Read 10284 times)
Re: floor pan
« Reply #1 on: August 22 2019, 02:24:13 PM »
The cheap one states it’s not an oe replacement but fits, the more expensive on looks like an oe replacement.
Re: floor pan
« Reply #2 on: August 22 2019, 03:04:40 PM »
If you look at the cheap one, it's smaller.  The expensive one goes all the way from the body seam, to past the front seat bolts.     With the lips and bosses and stuff, you have datum points to work with.
The cheap one looks like you lay it onto your rusty floor pan, pop rivet it in place, then carpet over it.
Re: floor pan
« Reply #3 on: August 22 2019, 10:51:21 PM »
So I wi probably need the $130 one if I am able to procure the car with the rusted Dr floor. Been looking at cheap tig machines but I'm really thinking I just need to get a bottle of c25 for my wire feed and go at it.
Re: floor pan
« Reply #4 on: August 23 2019, 02:29:22 PM »
Rock auto Rich. The shipping is ridiculous but you’ll get the full pan for less
Re: floor pan
« Reply #5 on: August 23 2019, 06:49:57 PM »
Cool, I'll look it up. You are getting the five percent off when you order right?
Re: floor pan
« Reply #6 on: August 23 2019, 07:52:46 PM »
Yep.  Discount code 11187024610560 6298
Bad part is those fuckers charge sales tax now.   And for some reason it's more than the 7% my area ''collects''.
