Author Topic: Alternator  (Read 12162 times)
Offline Tim Hensley
Alternator
« on: June 24 2019, 01:55:46 PM »
Can’t get a 87 buick 120 amp on the island this week
What is a possible replacement I might find?
DLS 210-210
Champion irons
Offline gnonyx
Re: Alternator
« Reply #1 on: June 24 2019, 10:25:08 PM »
Why not rebuilt your original Alternator?
Or is it damage beyond repair?
Re: Alternator
« Reply #2 on: June 24 2019, 11:04:37 PM »
See if they have one for a 94-96 impala.  Better alternator all the way around and 140 amps with a lot more at idle
Offline Tim Hensley
Re: Alternator
« Reply #3 on: June 25 2019, 01:37:37 AM »
No parts on the island I’ll check tomorrow on the impala
DLS 210-210
Champion irons
Offline reality
Re: Alternator
« Reply #4 on: June 25 2019, 06:31:05 AM »
If you're stuck any 1 wire alternator will work. A 105 works fine also in a pinch. Even 1 off a front wheel drive car but you may have to ''reclock'' it .Cars like a buick ultra have 120 amp too.
Re: Alternator
« Reply #5 on: June 25 2019, 10:26:44 AM »
Any junk yards where you’re at? I can pick up the 94-96 impala alternators for $25 here local
Offline Tim Hensley
Re: Alternator
« Reply #6 on: June 25 2019, 01:41:38 PM »
Thanks son got one at the zone and he shipped it yesterday he said.
Woohoo free shipping to Hawaii. Bet he gets it back some other way got love love your children
DLS 210-210
Champion irons
Re: Alternator
« Reply #7 on: June 25 2019, 01:56:00 PM »
Next time you go...grab me a couple :D
I find the junk yard versions better than the store versions
Offline Tim Hensley
Re: Alternator
« Reply #8 on: June 26 2019, 01:57:18 AM »
Ya junkyard price would be good.about 5 years back was a impala abandoned just below my house wish I new about the alternator fitting got a bunch of hardware think the alternator was junk.
Junkyard here only sale drugs
DLS 210-210
Champion irons
Offline 1KWIKSIX
Re: Alternator
« Reply #9 on: June 26 2019, 07:07:01 AM »
Only issue I have with the 94-96 Impala 140amp alternators are not being able to use the rear support bracket that bolts the assembly to the manifold stud.
You're OK, As long as you're running HR Parts Poly engine mounts, but if you are still using a ratcheting strap to minimize engine movement then you've got a concern as the extra stress / torque over on the unsupported alternator assembly could lead to an early demise.
Re: Alternator
« Reply #10 on: June 26 2019, 09:17:52 AM »
I quit using torque straps after it broke the ear off the end of the accessory bracket.  Seems the bracket was not engineered to hold the torque of a decent engine when the tires stick on launch.  That was about 25 years ago.
I remember others about the same time learned that lesson  :rofl: I later went to a single poly mount.
