Author Topic: MPH drop  (Read 14059 times)
Offline wmsonta
  • Turbo Street Stock
  • PSI: -1
Re: MPH drop
« Reply #45 on: June 24 2019, 06:22:45 PM »
I’ll post time slips tonight on the split
I would like to see the reaction times as you were staged somewhat shallow in the video.
Offline Tim Hensley
Re: MPH drop
« Reply #46 on: June 25 2019, 01:45:44 AM »
I didn’t care about reaction time just trying to figure out the lousy 60
Best 60 second best ET worst mph
1.687
4.749
7.361
93.04
9.630
11.556
117.13
At 3100 rpm 15 lb
DLS 210-210
Champion irons
Offline reality
Re: MPH drop
« Reply #47 on: June 25 2019, 06:24:14 AM »
Making good power on the back half [over 24 mph] but not putting it down in the front half. you are down approx 7 mph in the 8th. Comes back to the converter.IMO. What does it stall at 0 boost.
What exhaust housing on the car?
Offline wmsonta
  • PSI: -1
Re: MPH drop
« Reply #48 on: June 25 2019, 07:20:02 AM »
The numbers look good to me. The 60' is about .9 sec slow from perfectly fine. I do not trust 60' numbers until I see a 0.0x RT after a very shallow stage.
The car runs 'clean'. No antics, no apparent counter steer, pulls from start to the stripe. For a heavyweight street/strip G-body, I like it.
JMO.
Re: MPH drop
« Reply #49 on: June 25 2019, 10:25:18 AM »
Tim,
I have found that unless I get the boost in the upper teens low 20’s, I don’t see anything less than a 1.6 short time. I have a stock stroke .030 over 109. I stage at 35-3600 with the flash up to 4200.  Full boost usually comes in within .4 to .6 after the launch. The 1-2 gears can usually get away with a bit more timing and a leaner AFR. If you can get a log that would help folks make suggestions. Good luck and stay safe
Offline Tim Hensley
Re: MPH drop
« Reply #50 on: June 25 2019, 01:48:10 PM »
I’ll try again to post the log I’m not the sharpest knife. 35 to 36 not happening after adding timing I could before adding timing.
Think I flash at 4500? That’s were it falls to after every shift. Is that flash?
DLS 210-210
Champion irons
Re: MPH drop
« Reply #51 on: June 25 2019, 01:52:45 PM »
No, flash is the rpm that you hit as soon as you take your foot off the brake and the car moves about a foot or two.
If you can post a long, we will tell you
Offline Tim Hensley
Re: MPH drop
« Reply #52 on: June 26 2019, 02:11:38 AM »
hope this worked
DLS 210-210
Champion irons
Offline Tim Hensley
Re: MPH drop
« Reply #53 on: June 26 2019, 02:38:21 AM »
this is the right one
the first was no alky.I made a big booboo testing the Alky pump first thing and forgot to plug in the map.
it did answer a question I had about being so rich just before letting off the brake,it was nice and lean and same 60 foot time.and did not respond any different before KR
DLS 210-210
Champion irons
