Author Topic: MPH drop  (Read 14061 times)
Re: MPH drop
« Reply #30 on: June 22 2019, 12:11:47 PM »
looks like a nice day for a strip cruise
Offline wmsonta
  • Turbo Street Stock
  • PSI: -1
Re: MPH drop
« Reply #31 on: June 22 2019, 01:12:01 PM »
I liked the video. It runs good. Got air bags in the rear?
Re: MPH drop
« Reply #32 on: June 22 2019, 02:32:05 PM »
Nice run on the vid! Keep pecking away at the tune by trial and error is all you can really do.
Offline Tim Hensley
Re: MPH drop
« Reply #33 on: June 22 2019, 02:43:34 PM »
Thanks no bags
Hellwig bar
DLS 210-210
Champion irons
Re: MPH drop
« Reply #34 on: June 22 2019, 03:27:52 PM »
Have some one stand behind the car when you are spooling the turbo to check if the rear bumper is staying parallel to the ground.  If not, an air bag or a stiffer roll bar may be helpful.
Watch it on an actual launch as well at the strip
Kevin Slaby's rear upper control arms relocation kit is also a good idea given the poor geometry on a GBody as well
Offline wmsonta
  • PSI: -1
Re: MPH drop
« Reply #35 on: June 22 2019, 04:06:57 PM »
I didn't see any real issues, at this level. That is why I guessed air bags. Typically, a G-body is beginning to show symptoms @ 1.6 short.
I would not worry about it until it breaks loose as the rear unloads. They typically squat on the hit and unload in about 10-25 ft. This car apparently has good rear shocks and a smoooothe power delivery.
Anyway, you can video the launch and slow it down to find out. You probably won't feel it.
« Last Edit: June 22 2019, 04:21:49 PM by wmsonta »
Offline Tim Hensley
Re: MPH drop
« Reply #36 on: June 23 2019, 02:25:12 PM »
Three weeks ago. I added air fixed the tire spinning
DLS 210-210
Champion irons
Re: MPH drop
« Reply #37 on: June 23 2019, 03:12:23 PM »
what boost are you leaving at?
Offline Tim Hensley
Re: MPH drop
« Reply #38 on: June 24 2019, 01:26:25 AM »
15 to 20 at 3100 to 3600 at that you think it would be wheels up
DLS 210-210
Champion irons
Re: MPH drop
« Reply #39 on: June 24 2019, 08:40:04 AM »
117mph is solid horse power. Hooks well. Or seems to. Short time? What about the other splits? What kind of mph is it picking up In the second half?
Re: MPH drop
« Reply #40 on: June 24 2019, 09:47:21 AM »
I agree.  Something is not right at that point.  It should be wheels up or blowing the tires away. I would expect a 1.5 short time
Re: MPH drop
« Reply #41 on: June 24 2019, 01:22:43 PM »
It acts like it hits full boost after rolling out for a bit. Is it spraying alky while your spooling?
Re: MPH drop
« Reply #42 on: June 24 2019, 02:18:12 PM »
or, the converter is not doing its job and is absorbing the "Leave" instead of handing it to the rear tires?
Online reality
Re: MPH drop
« Reply #43 on: June 24 2019, 02:34:21 PM »
I would listen to Lonnie and Julio at this point. [converter]
With a 3500 n/l I didn't even notice it was there until I got in a stocker. I certainly never got the, wait for it to hit, people talk about.
Offline Tim Hensley
Re: MPH drop
« Reply #44 on: June 24 2019, 03:02:32 PM »
I’ll post time slips tonight on the split
Turned Alky of for a short 60 foot left leaned out to 12.2 no improvement in 60 ft time
Tried the 2 step at 3600 worst 60
Got enough data and time slips for Lonnie to restall the converter to best Mach my combo.
DLS 210-210
Champion irons
