Author Topic: Heater box sealing  (Read 15188 times)
Offline Norm340
Heater box sealing
« on: June 16 2019, 03:39:17 PM »
I'm looking for what would be best to use to seal the outside top of the heater/AC box at the firewall.
OEM looked like a thick tar that has harden over the years.
Kinda thought of maybe using a black seam sealer and or Windshield sealant or something similar?
Any ideas would be appreciated.
Thanks
Re: Heater box sealing
« Reply #1 on: June 16 2019, 04:42:29 PM »
Sounds alot like butyl tape that glazers use. I have forgotten what the specific automotive version is called.
« Reply #2 on: June 16 2019, 04:44:07 PM »
"3M strip caulk " might work?
Offline Norm340
« Reply #3 on: June 16 2019, 06:57:35 PM »
I was going to use that strip caulk for the lower part of the box.
But when looking for the Butyl tape you mentioned earlier I did find this.
MONO Silicone PRO Premium Silicone Rubber Sealant
https://www.homedepot.ca/product/mono-silicone-pro-premium-silicone-rubber-window-door-sealant-black-290-ml/1001001863
« Reply #4 on: June 17 2019, 08:25:38 AM »
That'll work as long as you never want to get that heater box off again.
and those guns are bad about drips and stuff after you release the trigger.
« Reply #5 on: June 17 2019, 10:18:16 AM »
I'm with Earl on both points.
PS (and you may alread know this):Good habit to develop is when u stop squeezing immediately release the plunger with your thumb and throw a paper towel under the tip- at least it give you a chance
« Last Edit: June 17 2019, 10:22:52 AM by daveismissing »
Offline Norm340
« Reply #6 on: June 18 2019, 04:01:28 PM »
I definitely would like to get that heater box off in the future.
If not for me then for the next guy who owns this car.  :icon_smile:
So what would be good to use then?
Thanks you guys
« Reply #7 on: June 18 2019, 11:56:34 PM »
I used some kind of weatherstrippi ng seal that came in strips arrayed on a waxy paper...forget what it was called.  May have been by 3M? strip caulk?
Offline Norm340
« Reply #8 on: June 19 2019, 11:30:17 AM »
Hey you guys thanks for all the input/help.
3M strip caulk it is then.
I'll throw the link below just to be sure I'm using the right stuff.
https://www.napaonline.com/en/p/MMM08578
Thanks again.
« Reply #9 on: June 19 2019, 10:45:06 PM »
Of course, I have not tried to take the top off since.....:D
« Reply #10 on: June 20 2019, 09:17:54 PM »
Good for stickin' the brown paper back onto the inner doors too
Offline 6 PAK
  • Newbie
« Reply #11 on: January 29 2020, 10:43:06 PM »
I used what they called " Dum Dum ". Wet your fingers while you remove it from the tape. I was told some dealerships use it. About $12.00 for a roll at Advance.
87 GN
87 Turbo T
99 Chevy Tahoe
93 Chevy (INDY PACE) Truck
« Reply #12 on: January 29 2020, 11:16:49 PM »
Dum dum...
I have not heard that name in years :)
