Author Topic: Adjustable upper arms  (Read 5645 times)
Offline Tim Hensley
« on: May 02 2019, 02:29:27 AM »
at what ET will adjustable upper help your 60 foot time?
Car sitting centered on frame, proudly one of the few.
I only make enough HP to go high 11s.
I ask because it’s been 3 mouths since my last new purchase for this car and I need to keep my wife use to my bad habit,I go any longer and she’ll think something wrong.
DLS 210-210
Champion irons
Offline ss/gn
Re: Adjustable upper arms
« Reply #1 on: May 02 2019, 06:27:06 AM »
Stock with a good bar and shocks have gone 9s.   :powersix:
Kevin
« Reply #2 on: May 02 2019, 08:58:49 AM »
Invest in a fresh tank of gas.  It would be a waste on the upper arms
Offline Tim Hensley
« Reply #3 on: May 02 2019, 11:39:31 AM »
Thanks just as I was laying my head down I relived this moment.
Gas is a good suggestion
DLS 210-210
Champion irons
« Reply #4 on: May 02 2019, 01:36:00 PM »
I’ve seen some 1.4ish 60 foot times on stock stuff. A good rear sway bar to keep you straight at launch would be my suggestion
Offline Tim Hensley
« Reply #5 on: May 02 2019, 02:30:22 PM »
I have a Hellwig bar wish I had got the HR bar
But this car goes straight every time. Really my next purchase should Be slicks.
Been running 28X9 Hoosier thinking of MT 28X9 Pro bracket or Et street R
DLS 210-210
Champion irons
Offline gusszgs
  • Limited quick brick
« Reply #6 on: May 03 2019, 09:25:46 PM »
JMO, but I’m pretty happy with the adjustable UMI uppers I run. Installed properly with the right PL on the PS bar, my car not only lost .12 in the 60’, but also centered up the rear more square and I could eliminate the very small spacer I required on one side. Dropped to high 1.50’s 60’ from struggling to run a 1.7 on same tire and set up.
Jim
1987 T Limited
« Reply #7 on: May 05 2019, 10:49:05 AM »
Funny I was just thinking about replacing mine with spherical rod ends to eliminate bind.
Online Forzfed
« Reply #8 on: May 05 2019, 01:41:38 PM »
An air bag can help you out a bit too.
Is that with slicks or DR's?
« Reply #9 on: May 06 2019, 04:42:53 PM »
DR
« Reply #10 on: May 07 2019, 05:23:26 PM »
Stock uppers, Metco billet lowers, 90/10s up front, QA1 rear single adjustables, ATR rear bar, used 28x9 slicks. 1.5's off the foot brake flashing the convertor to 3950 on a less than stellar track. Suspension tuned by Scoob...of course!
« Reply #11 on: May 08 2019, 09:51:36 AM »
Loving the idea of looking to keep the wife use to the bad habits. Lol.
Offline Tim Hensley
« Reply #12 on: May 10 2019, 01:17:41 AM »
Well A new problem has arisen to keep her on her toes.The fuel pump died on a small road trip to Kona.on the return trip home right smack in the middle from Kona  and home the fuse to the fuel pump cut,no spear, picked up a old beer tad and installed it and nothing.$80 dollars for a tow home.
DLS 210-210
Champion irons
