Welcome to IHADAV8.com!
3 year old 02
Topic: 3 year old 02 (Read 5247 times)
Tim Hensley
Turbo Street Modified
Boost n00b
3 year old 02
April 02 2019, 03:16:04 AM »
My 02 is 3 years old but has only 3000 miles on it ,just pump gas and a gallon of methanol.It should be good for one more year?RIGHT
DLS 210-210
Champion irons
Re: 3 year old 02
April 02 2019, 09:52:15 AM »
or 5 or 6
gusszgs
PSI: 1
Limited quick brick
Re: 3 year old 02
April 02 2019, 11:11:40 AM »
Holy shyte bro, mine Denso 1001 has been in my Ltd for at least 10 yrs now. Still good
Jim
1987 T Limited
Tim Hensley
Boost n00b
Re: 3 year old 02
April 02 2019, 02:16:55 PM »
Thanks I relying on it I have TT 6.3
DLS 210-210
Champion irons
TexasT
Legend in my own mind
PSI: 1
So, This black car is fast?
Re: 3 year old 02
April 02 2019, 03:25:09 PM »
Do your o2 readings look good?
Scoobum
Re: 3 year old 02
Reply #5 on:
April 02 2019, 04:06:11 PM »
With the engine warmed up, if the 02's are moving slower than 1 per second then it's fukd. Do you really wanna chance an engine on a 20 dollar part.
One last time. With Erics 6.1 chip if the NB and WB aren't in perfect working order, then you're in for a world of hurt.
Re: 3 year old 02
Reply #6 on:
April 02 2019, 04:45:51 PM »
My experience is that a part that is working correctly is more like to be good than a new part that has yet to be proven.
reality
Boost n00b
Re: 3 year old 02
Reply #7 on:
April 02 2019, 05:39:49 PM »
If it's not broke- fix it till it is.
Scoobum
Re: 3 year old 02
Reply #8 on:
April 02 2019, 10:08:16 PM »
Steve and Ron are correct. Disregard what I said.
Re: 3 year old 02
Reply #9 on:
April 02 2019, 10:51:29 PM »
I should have noted that my comments only apply to an O2 sensor that has only seen non-leaded gas thru the fuel system and is still properly active on the cross over counts as Brad mentioned....
Tim Hensley
Boost n00b
Re: 3 year old 02
Reply #10 on:
April 03 2019, 03:19:56 AM »
My bad TT6.1
Yes it is very responsive on and of the gas.Yes WB NB seems to be going in the same direction.
I got to thinking about what has been said,so I looked at some older logs and the most resent,they look very similar.
Thanks again I ask the question you guys come back with good feedback,the old brain starts to work and I fill good about letting it ride and keep a eye one the numbers.
DLS 210-210
Champion irons
Top Speed
Don't Tread on Me
PSI: -2
Re: 3 year old 02
Reply #11 on:
April 03 2019, 11:51:33 AM »
They can last a while as long as no leaded gas is used.
Champion Irons w/T&D roller rockers, TA-61 turbo, 206/206 Comp Cam, 57 lb/hr Siemens Injectors, 3000 stall PTC, PTE Plenum w/RJC Power Plate, 70 mm Accufab Throttle Body, RJC 325 Megacooler, TurboTweak 5.7/ Alky Control w/M1 methanol, 23 psig on the street, Puddn' Power engine, Borla Exhaust
3 year old 02
