Author Topic: Motor mounts  (Read 10139 times)
Re: Motor mounts
« Reply #15 on: February 13 2019, 04:53:29 PM »
Cheapass ones on mine...surpris e surprise. RJC transmission motor mount for launching. Works mint...no vibration.
Rubber engine mounts and a poly trans is begging for a cracked trans case :hmm
5 million launches and counting.
Re: Motor mounts
« Reply #16 on: February 13 2019, 06:00:11 PM »
buy lottery tickets!  :D  the physics are obvious :)
Offline reality
Re: Motor mounts
« Reply #17 on: February 13 2019, 08:22:56 PM »
Brad. you are leaving yourself wide open with that statement  :D
Offline wmsonta
  • Turbo Street Stock
  • PSI: -1
Re: Motor mounts
« Reply #18 on: February 13 2019, 08:48:46 PM »
Like Scoobum, I do not remember any cracked trans cases with conventional style mounts of any kind. I have seen broken mounts and all kinds of trans issues.
The old gasser's were somewhat famous for it. They had round tubing chassis and tied in motor/trans plates.
Not saying it doesn't happen, rather I have not seen it. I have seen oem style solid mounts used, but not in all 3 locations.
Years ago, i had a guy go though 8 powerglide cases in 3 seasons. Those cases let go internally.
In '71, I built a motor for a guy who had a clutch explosion that tore the hood off the hinges. Plus considerable other damage. I bought the motor back cheap.
Re: Motor mounts
« Reply #19 on: February 13 2019, 09:37:20 PM »
How many of those that you are recalling had either solid or near solid poly transmission mounts under the tail shaft and conventional rubber mounts on the engine without some form of tie down?
Offline wmsonta
  • PSI: -1
Re: Motor mounts
« Reply #20 on: February 13 2019, 10:04:33 PM »
The quick answer is none. Everyone I know is concerned with the drivers side motor mount. I consider poly nearly the same as solid.I have seen one or both motor mounts solid.
The answer to the Gasser problem was a front and mid plate w/rubber trans mount. Homemade or oem.
Re: Motor mounts
« Reply #21 on: February 13 2019, 10:27:46 PM »
You missed the subject of the latter discussion which was very the use by of a solid tranny mount with rubber engine mounts 🙂
Offline wmsonta
  • PSI: -1
Re: Motor mounts
« Reply #22 on: February 13 2019, 11:02:57 PM »
As a matter of fact, I did.
Re: Motor mounts
« Reply #23 on: February 14 2019, 12:26:01 AM »
I do it all the time...LOL
Re: Motor mounts
« Reply #24 on: February 14 2019, 08:58:27 AM »
And back to my original point, these cars are a small market so many of the parts are expensive.
However I don't see why even a properly engineered and built mount should sell for over $100
Offline reality
Re: Motor mounts
« Reply #25 on: February 14 2019, 10:53:05 AM »
OK, I gotcha now, And especially when they sell copied parts
 I once bought a double roller timing chain from LC and paid $139.99 US. I found the same chain in CAN for $69.95 CAN.
Live and learn I guess.
Re: Motor mounts
« Reply #26 on: February 14 2019, 12:06:48 PM »
Yep, I have been bit by that pricing bug....more than once...LOL
Re: Motor mounts
« Reply #27 on: February 14 2019, 05:28:44 PM »
Steve, I'll never argue physics with you. Jason sells two versions. A heavy duty...and a light duty version...whic h is the one I have. It's pretty flexible. You actually have to bend/contour it to get the correct angle to mate it to the frame. It's also adjustable...a nd I've got it set pretty soft.
I've done all the hard work for these guys. Complete stock junk build is on my vids. A couple years back I posted the complete tune up on the car for a run for the car from each outing for the year. I included, ET, MPH, 60 foot, launch RPM, shift points, humidity, temperature, low/high gear fueling and low/high gear timing. Did anyone listen...no. They went out and bought cool guy parts and struggled. Like Grumpy says. You can lead a horse to water...but you can't make him drink.
Re: Motor mounts
« Reply #28 on: February 14 2019, 05:40:48 PM »
got no argument from me!
Offline reality
Re: Motor mounts
« Reply #29 on: February 14 2019, 10:55:59 PM »
This is what I think of physics
https://www.youtube.com/watch?v=M2_kQ1Bf1js
