Zap *STILL* wears Depends
a couple months at the most.
I used the Yamaha Carb Cleaner because I had it and I know how well it works on bike and ATV carbs. (and doesn't eat plastic or rubber). Since it's designed to dissolve gas varnish and doesn't eat base material, I figured it'd be great to keep varnish from happening in the first place.
Without doing anything, I'd give them a couple months at the most. ESP if you do it now, because the refineries are making 'winter blend' which flashes off even faster than normal.it's really not that complex. If you have a second set of hands, you could take a 9volt battery and it's wires to do the same thing. I'm sure 9 volts would be enough to chatter the little electro magnet just to get some jizz in there.My test rig sounds more complex than it really was. I had a 12V cordless drill fall of my deck and break in two. I was left with a handle/trigger that had two wires poking out the top and a 12V battery on the bottom. It was perfect for applying momentary pulses of 12V since the trigger is already a momentary switch. I used the Yamaha Carb Cleaner because I had it and I know how well it works on bike and ATV carbs. (and doesn't eat plastic or rubber). Since it's designed to dissolve gas varnish and doesn't eat base material, I figured it'd be great to keep varnish from happening in the first place.
