Author Topic: Wideband sensor life  (Read 11087 times)
Re: Wideband sensor life
« Reply #1 on: January 14 2019, 10:28:55 AM »
Nope!  I don't have a crappy Bosch!  They die fast on leaded fuel.  I have had buddy's NTK sensors last 7 years on pure race fuel diets.  Even if I was using only pump gas I would stick with the NTK.  NGK for the win!
« Reply #2 on: January 14 2019, 11:44:16 AM »
I read that with Bosch , "you can buy better, but you can't pay more."
Post #16 but you have to be logged in to see it.
https://www.garagejournal.com/forum/showthread.php?t=412363
« Last Edit: January 14 2019, 11:49:57 AM by TexasT »
« Reply #3 on: January 14 2019, 03:55:53 PM »
NTK all the way.  I have seen too many Bosch go bad.
« Reply #4 on: January 14 2019, 04:26:15 PM »
Buying a quality controller/sensor will save you time and money. With cheaper stuff the 0-5v output is a mess, and you could have ground offset issues. Some of the newer cheap controllers come with serial out to eliminate the issues with analog - but your software has to support it and still stuck with a mediocre sensor.
