Author Topic: New T codes 32 and 44  (Read 13524 times)
Offline gusszgs
  • Limited quick brick
Re: New T codes 32 and 44
« Reply #30 on: January 02 2019, 12:35:49 AM »
Yepper Dave
That’s her. Did you know the gent?
« Last Edit: January 02 2019, 12:40:15 AM by gusszgs »
Jim
1987 T Limited
« Reply #31 on: January 02 2019, 04:46:55 AM »
Jim...appears that's a Monte SS style exhaust...and possibly not turbo mufflers.
Offline gusszgs
« Reply #32 on: January 02 2019, 10:53:02 AM »
Yes it is. Lol.....and it’s coming off and Hooker CT is going on.
Jim
1987 T Limited
« Reply #33 on: January 02 2019, 05:59:58 PM »
My dad was in the care facility across the street. Flat tires and the racks caught my attention. It may have had a cover on it at some point. Mid Dec '17 was the last I was there.
Offline gusszgs
« Reply #34 on: January 02 2019, 07:31:25 PM »
She definitely needed some TLC.....gettin g there
Jim
1987 T Limited
Offline gusszgs
« Reply #35 on: February 11 2019, 03:27:13 PM »
Ok, got side tracked with detailing and such but had it running again today. TT Chip installed! MAF hose is/was in good shape but yes, I’m guilty as I missed a couple of very small tares which where repaired. (Thin smear of right stuff on inner and outer surface)
Started it up this afternoon and INT is 128, BL still at 142. All other values look good.
So while prowling around under the car on jack stands looking for my source of oil leak (brand new valve covers gaskets installed) so I’ve eliminated that possibility (nice n dry up there) I discovered the exhaust IS leaking at the DS crossover. I can feel it against my hand on block side.
So, I will pull the crossover off and go from there, as it looks like I have to do the pan gasket and rear main seal anyway
Thanks to all you guys for your input. Yes, I feel like an ass!! 😂
« Last Edit: February 11 2019, 04:19:28 PM by gusszgs »
Jim
1987 T Limited
« Reply #36 on: February 11 2019, 04:10:58 PM »
Jim...if the crossover pipe is fukd...don't get one from Kirbans. I grabbed one from them a few years back...and it didn't come close to fitting. The studs will prolly snap. Pull the header...it ain't that hard...and install new ones. I know you don't like gaskets...but if any exhaust gases escape to the atmosphere it'll spool slower and your BLM's will be out of whack. I run both header gaskets and a turbo flange gasket. I've got 'er sealed up tight. Ya' I know. They never had gaskets...but after a gazillion heat cycles...stuff warps.
Offline gusszgs
« Reply #37 on: February 11 2019, 04:28:28 PM »
Thx, yes I’ve done the headers a number of times.
I’ll pull the crossover off and see what’s going on with the ball n flange there. I have to do the pan gasket anyway so I’ll dig in. To me it looks like some stooge has been in there trying to fix the oil leak and installed the gasket wrong, but at the rear of block you can see ALOT of the rubber gasket hanging out from the pan. Almost looks like they missed the bolt holes in the gasket lmao WTF??
 :rolleyes;
Jim
1987 T Limited
« Reply #38 on: February 11 2019, 09:55:13 PM »
The gasket in question
Offline gusszgs
« Reply #39 on: April 02 2019, 09:28:25 PM »
Just an update guys. I FINALLY got the car running to perfection!
It was a combination of a number of things but mainly a serious DS header leak ( there’s a surprise uh) poor rotted vacuum lines, injectors and dialing the tune back in. Proper gapped plugs wires ect.
It’s running absolutely fantastic!
Just a big thank to EVERYBODY’S input! The cars can certainly be a challenge at times. It’s been 5 months almost to the day since I bought this, so definitely a lot of work in her. Still lots but real sweet having it running perfectly, all parameters on SM are bang on.
Jim
1987 T Limited
« Reply #40 on: April 02 2019, 09:42:40 PM »
It's a great feeling!  I'm glad you got there with it :)
Offline gusszgs
« Reply #41 on: April 02 2019, 10:04:14 PM »
Thanks Steve
Jim
1987 T Limited
« Reply #42 on: April 03 2019, 10:33:41 PM »
Always nice to accomplish something. Glad for you now get out and enjoy it!
Offline gusszgs
« Reply #43 on: April 07 2019, 12:13:08 PM »
Thx Jason
Sneaky vacuum lines lol
Yes great feeling to have it running it think as good as a stock TR is capital of.
Jim
1987 T Limited
