If it’s opening up the egr all the time the vacuum lines are routed wrong or the egr solenoid could be bad.
Quote from: Steve Wood on December 22 2018, 08:15:50 AMOkay...put the TT chip and start looking for the air leak both in the exhaust and the intake side. Be sure the plenum is not leaking. All signs point to a leak at this momentThank you Steve As stated I did all vac lines ect...Does the MAF reading look wrong? I believe my Limited is about the reading at idle.I also ment to mention the SES light comes on intermittently .....kinda strange as it mostly comes on at idle, then when driving the car it will go out then back on again.I also tried the propane trick around all vac sources to see if idle changed...noth ing.Just thought of one thing I didn’t do and that was to see if the EGR solonide is commanding vacuum at idle. BUT as said, I will follow advice and install TT chip before moving forward.Brad, thanks so much for offer, I’m pretty busy over the holidays and such but will be in touch if the chip and other checks don’t help me make some leeway.
