Author Topic: Exhaust ideas  (Read 8758 times)
Re: Exhaust ideas
« Reply #15 on: September 26 2018, 11:57:37 AM »
LOL, they do sound good.  On a Turbo 6 at WOT it is a sound that has to be heard to be appreciated.
Re: Exhaust ideas
« Reply #16 on: September 26 2018, 12:58:52 PM »
The Hooker catback system has come with different mufflers over the years. Just to be clear, and I understand you stated you have the same system, but did your system come with the aerochamber mufflers? Just for more info on my car, I'm running a 6262 Precision turbo, Champion ported irons with match ported intake, 212/212 cam w/roller rockers, and a .030 over motor. And ........ no drone.  :D
Yes it came with the same mufflers!  But I have a 224/224 cam with ported Champions and 4.1.  Like I said it was the big A/R on the exhaust that did that. It never did it before and it sounds good WOT!
Re: Exhaust ideas
« Reply #17 on: September 26 2018, 04:21:32 PM »
Re: Exhaust ideas
« Reply #18 on: September 26 2018, 05:15:27 PM »
that video  :rofl:
Re: Exhaust ideas
« Reply #19 on: September 26 2018, 06:38:09 PM »
No restriction there!  But does it drone? :icon_lol:
Re: Exhaust ideas
« Reply #20 on: September 26 2018, 10:05:31 PM »
How many day long trips are you people taking that some drone is a problem?
Re: Exhaust ideas
« Reply #21 on: September 26 2018, 10:23:56 PM »
Drone is really annoying in minutes...
Re: Exhaust ideas
« Reply #22 on: September 26 2018, 10:29:02 PM »
Yes it is!!
Re: Exhaust ideas
« Reply #23 on: September 27 2018, 12:19:30 AM »
I daily drove my GN with a 'droning' 3" ATR single shot over 600miles a week, every single week right up until it was stolen.    It was amazing how much more ass the exhaust note had when the 250,000 mile stock engine got replaced with a high compression, big cam, roller 4.2L.
  I'll take the sound of the drone at cruise over the horrible sound of a Buick V6 at full honk any day of the week.
Re: Exhaust ideas
« Reply #24 on: September 27 2018, 08:47:20 AM »
i really enjoy the drone personally!!!
Re: Exhaust ideas
« Reply #25 on: September 27 2018, 09:17:17 AM »
If you love the drone, buy a pair of the turbo mufflers that were popular for at least five minutes on Regals in the early days!  :D
