Author Topic: Tire MPH question  (Read 7385 times)
Re: Tire MPH question
« Reply #15 on: September 24 2018, 08:07:58 AM »
I wonder what it does when the GPS looses lock or during acquisition.
Tire MPH question
« Reply #16 on: September 26 2018, 07:08:06 PM »
Well I just thought I would report back on the sky drive GPS.
It works as advertised easy to wire up to my computer. It’s a little slow at low speed. Drops off under about 10 mph but once it’s going it works well.
Should be more than enough to operate lock up and eliminate codes if you have a flakey VSS.
I gonna post a a thread for Eric with a log to see if he thinks it’s good enough use for fuelling and timing in 1st and second gear with one of his chips.
« Reply #17 on: September 26 2018, 07:57:43 PM »
sounds good.  Just don't race anyone in a tunnel :D
« Reply #18 on: September 27 2018, 12:53:08 AM »
Should work good enough.   For right at a decade since I got into speedboats, the hot ticket is to have a GPS speedo.
Granted that's to verify actual top speed and boats don't spend a lot of time in tunnels, but I can't imagine you could blow an engine at 8% throttle if the GPS doesn't report to the chip for a few sexonds.
Tire MPH question
« Reply #19 on: September 27 2018, 12:38:54 PM »
Worse thing that could happen is maybe a code I think if it lost its signal.
