AlkyControl Alcohol/Methanol injection
Author Topic: Where do most of the content in this site come from? Is it possible to share.  (Read 9968 times)
Underwooz
  • Guest
I want to know that new knowledge. Where can I get this from, and can you recommend me?
Offline Grumpy
Steve Woods brain.  :cheers:
My brain is rotten.  When you try to share it, it crumbles like last week's cake.  Don't let your hamster eat the green parts.  Mould is bad for hamsters.
These bots spit out some pretty consistent nonsense, surprised forum addin software can't weed them out.
Steve Wood's hard drive!  Not to be mistaken with Earl's hard drive which is totally different.
Might as well go right to the source for new knowledge.
Everything on this site is plagiarized from https://www.crazyshit.com/category/extreme-content/
This site is mostly photo shopped
Proof positive. That 43 shouldn't be there
