Author Topic: RJC boost controller?  (Read 26535 times)
Re: RJC boost controller?
« Reply #15 on: August 28 2018, 02:06:18 PM »
Earl, I'm aware of how it works.  The bleeder actually did the same thing but was unpredictable when the weather changed.
I've had this thing sitting on the shelve for years.  Damn you for not making one sooner! :) Everything about yours just makes more sense.
« Reply #16 on: August 28 2018, 02:32:06 PM »
I'm amazed that site is still online.
Last updated 16 years ago.
Wow, the guy (Gus) passed away in 2002, I guess his pals are keeping the site up.
« Reply #17 on: August 28 2018, 10:16:17 PM »
The bleeder valve changed because of density of air has different flow characteristic s when the temp is different.
  The MBC uses spring preload that isn't affected by temp.
I'm amazed Kenne Bell sold any of those goofy things.  If all you wanted was a constant air leak from the wastegate hose, all it'd take is a sewing needle to put a hole in it.
