Author Topic: TR6 problems  (Read 11981 times)
TR6 problems
« Reply #30 on: August 31 2018, 07:11:19 PM »
14 on the logs
Re: TR6 problems
« Reply #31 on: September 02 2018, 11:18:15 AM »
put an old chip in it 5.7 I think burned with 25 degrees of timing turned it down to 17 PSI on a preliminary test hit it seemed fine but  was very fat. I will tune it a bit and let you know how I make out.
Re: TR6 problems
« Reply #32 on: September 03 2018, 04:17:56 PM »
so I pulled some timing and added boost to lean it out, seems to be working great a couple hits from a dig and its ripping must have gotten some moisture in the computer or the chip somehow. I have relocated the computer and positioned it to avoid this in the future.
Re: TR6 problems
« Reply #33 on: September 03 2018, 05:46:34 PM »
sounds like some progress to me!
