Author Topic: Alky Tank Leak?  (Read 4337 times)
Alky Tank Leak?
« on: August 10 2018, 03:01:47 PM »
So, I have 3/4 of the kit installed and I am going to get a buddy to finish it off.  Working nights so I can't spend much time on it.  I put a little methanol in the tank and noticed it is leaking right where the braided line connects to it.  Can you tighten that line?
Offline aminga
  • Chicks Dig the Power Bulge
Re: Alky Tank Leak?
« Reply #1 on: August 10 2018, 04:05:38 PM »
I think that is a pressed in fitting and can't be tightened.
I had to get a new tank one time because of it
Re: Alky Tank Leak?
« Reply #2 on: August 10 2018, 04:27:48 PM »
Ah, crap! :(
Re: Alky Tank Leak?
« Reply #3 on: August 10 2018, 05:13:22 PM »
During the install Razor suggests using water just in case an occurrence like this happens...less corrosive spill. Good luck with the install and hopefully that works out. :rock:
Re: Alky Tank Leak?
« Reply #4 on: August 10 2018, 05:52:44 PM »
Sounds like it's not going to work out! :icon_confused:
Offline The Radius Kid
Re: Alky Tank Leak?
« Reply #5 on: August 14 2018, 11:41:12 AM »
This sounds lie something I ran into before.
Got a pic' or the offender without the hose on?
Re: Alky Tank Leak?
« Reply #6 on: August 14 2018, 11:55:48 AM »
I talked to Julio yesterday.  He said it is the same connection like a boost gauge.  The fitting was very loose.  So that is tightened up.  But I ordered an extra tank for my inventory! :D
