Author Topic: Endoscope  (Read 4517 times)
Endoscope
« on: July 28 2018, 11:09:43 AM »
About a year ago, I bought an endoscope to use with my phone..it is an Depstech if you want to tell me how much better yours is  :068:
It works great and the only downside is that I have a usb-c port on my phone so it needs an adapter to plug in.  Very handy to see where I cannot see.
Recently, I could not find the adapter which chapped me off.  I bought another one..same brand...that works off wifi.  Now, this thing is great.  I can plug it into my battery storage pack for power, prop the phone up wherever I want and concentrate on aiming the probe.  I used it yesterday to look thru the valve cover bolt holes to be sure, I had the cover lined up right.
Eliminating the cable to the camera makes it much easier to take a pic or movies without losing aim of the probe.
I bet Earl has a bunch of these things for examining various orifices
Yeah, I found the adapter about 30 minutes after ordering a new one...of course, but, they are cheap and I like the new one
Re: Endoscope
« Reply #1 on: July 28 2018, 03:04:21 PM »
Earl has a cell camera made by Caterpillar with FLIR on it.
I can see the good stuff in the dark...      AND  underwater if I want to!!  ;)
Offline BoostedRPS
  • PSI: -1
Re: Endoscope
« Reply #2 on: July 28 2018, 09:36:12 PM »
I need a new Endoscope that has a smaller "head" than what I currently have now. Between my Milwaukee scope, and this other wireless one, the camera on it has about a 1.5-2" solid stiff piece on it before it starts to be flexible.
I need something that has a smaller camera end on it, so that I can go around tighter turns and bends.
Is this the scope you're using currently?  https://www.amazon.com/dp/B077XWJP2T/ref=sspa_dk_detail_0?pd_rd_i=B0785H3XR7&pd_rd_wg=0sjwG&pd_rd_r=VD55PZMV4BBHC754GRW5&pd_rd_w=Yc44z&th=1
Re: Endoscope
« Reply #3 on: July 28 2018, 10:10:56 PM »
Wireless Endoscope, Depstech WiFi Borescope Inspection Camera 2.0 Megapixels HD Snake Camera for Android and IOS Smartphone, iPhone, Samsung, Tablet - Black(33FT) https://www.amazon.com/dp/B01MYTI2HV/ref=cm_sw_r_cp_apa_i_4esxBb134F354
Re: Endoscope
« Reply #4 on: July 28 2018, 10:33:01 PM »
Damn it,  Steve.  Now I have to buy one and check it out.
« Last Edit: July 29 2018, 09:09:00 PM by Top Speed »
Re: Endoscope
« Reply #5 on: July 28 2018, 10:49:17 PM »
Damn, it  Steve.  Now I have to buy one and check it out.
LOL...it's really handy!
Re: Endoscope
« Reply #6 on: July 28 2018, 11:10:38 PM »
The one Tyler linked is the one I would buy today.  bigger battery and longer focal length.  I had not used mine for awhile so I plugged it into my back up pack...used that and charged the onboard battery
Offline TurboCajun
  • Keith Theriot
  • 6 Packed
