Author Topic: Connecting Wideband to Power Logger?  (Read 3302 times)
« on: July 26 2018, 09:12:31 PM »
I finally pulled my DS out and put the Power Logger in and got it going.  Loading the drivers was weird I tried a few different methods till I finally got one to work.  And I updated my Laptop, that took an 1 1/2 hours with 134 updates!
I'm going to tackle putting in my 80lb injectors this weekend.  My question is weird did you guys mount the board that connects the wideband to the PowerLogger?  For some strange reason I originally thought it was part of the PL.
Thanks,Nick
Re: Connecting Wideband to Power Logger?
« Reply #1 on: July 26 2018, 09:15:06 PM »
If you flip the glovebox down, there's a perfect little nook on the HVAC box just left of center. Below the hot-cold bellcrank.
« Reply #2 on: July 26 2018, 09:18:16 PM »
I was thinking somewhere there.  Thanks, Earl. :cheers:
« Reply #3 on: July 26 2018, 09:30:44 PM »
There's a pic on Steve's vortex site under the how to section, in the installing map sensor for powerlogger section. http://www.vortexbuicks-etc.com/PowerLogger.htm
« Reply #4 on: July 26 2018, 11:35:15 PM »
I remember reading that, it's a good one!  Thanks.
