Author Topic: Power Logger?  (Read 10859 times)
Power Logger?
« on: July 17 2018, 07:59:44 PM »
So I am finally getting around to installing my Power Logger.  I copied it onto a usb and onto my laptop with windows 7.  When I go to open it the window is only 3/4 of the screen and the full screen in the top right corner is not available.  Andy ideas?  Also is there anything else I need to know?
Thanks,Nick
Re: Power Logger?
« Reply #1 on: July 17 2018, 08:35:07 PM »
It's a fixed screen size made for older laptops that had small screens..what yu see is what wu gets
Re: Power Logger?
« Reply #2 on: July 17 2018, 08:37:03 PM »
Re: Power Logger?
« Reply #3 on: July 17 2018, 08:39:11 PM »
If you haven't got the latest version get it and try it. That info is from a year ago...maybe something in a new update to help?
Re: Power Logger?
« Reply #4 on: July 17 2018, 10:39:36 PM »
So, it is the best and most sophisticated logging tool for the Buicks but you can't read it! :hmm
Re: Power Logger?
« Reply #5 on: July 18 2018, 02:55:12 AM »
Change the resolution on the laptop to the lowest setting available. That's normally the right size.
Since my PL laptop is mainly for the car, I added PL to the start menu too. That way it goes ahead and launches when I turn on the computer.  Good time saver, esp if the sun is out.
Re: Power Logger?
« Reply #6 on: July 18 2018, 10:06:01 AM »
I will try that Earl.  Good call on using the start up menu I haven't done that in forever! :cheers:
Re: Power Logger?
« Reply #7 on: July 18 2018, 01:44:01 PM »
That start up menu works great!  I have the laptop set up for the power logger and the home station set up for porn hub! :tongue
Re: Power Logger?
« Reply #8 on: July 18 2018, 02:53:55 PM »
If you use ROKU streaming device, Pornhub has an app for that too.
...as of a few minutes ago, it's working fine.
