Author Topic: Turbo Tweak GN ECU  (Read 51176 times)
Re: Turbo Tweak GN ECU
« Reply #30 on: July 13 2018, 08:11:51 AM »
That's a very nice write up and it answers my questions.  It has enough inputs that it can handle
Satellite TV and still go fast. :D
« Reply #31 on: July 13 2018, 08:13:56 AM »
It has lots of cool guy features, I'll give it that.
« Reply #32 on: July 13 2018, 08:25:05 AM »
They took a well proven platform and tailored it for the Buicks so they did not re-invent the wheel but they customized it specifically for our cars and added enuf features to make it run out of the box without having to import a trained monkey to tune it after each race.
The best thing is that it was brought to market by two really nice guys that have always bent backwards to help people.
« Reply #33 on: July 13 2018, 09:27:50 AM »
Eric has an excellent support forum for his products and Bobs. The support for this ECU will be second to none...compare d to the alternative.
« Reply #34 on: July 13 2018, 10:25:36 AM »
Jason did you verify timing ignition timing?
Steve - until people stop tuning off knock threshold they are still going to break stuff.
« Reply #35 on: July 13 2018, 11:48:43 AM »
All I know, is that if one is running 25+ psi of boost and the fuel hiccups, one has a very expensive mess left under the hood.
I don't know exactly what you mean by knock threshhold as I have always run a couple of percent more fuel at a minimum than what testing showed I could run without detonation as I have found it makes minimal difference in performance to be a little rich.
I also know that fuel quality varies as do ambient conditions and I like to stay away from all the possible lines that I can think of.  Having a management system that tries to save the engine seems like commonsense to me if something goes wrong.
Having the ability to monitor fuel pressure and alert me early is better than finding out that the pump is going away too late.
I distinguish between warnings and tuning.
« Reply #36 on: July 13 2018, 12:40:23 PM »
Steve - I’m talking about the guys that keep turning it up until it knocks, and dialing it back some. Where they could have snuck up on it and found that it’s perfectly happy with less timing than they are trying to feed it.
This ecu can do all of what you want and then some.
« Reply #37 on: July 13 2018, 01:23:50 PM »
Most need to be saved from themselves.
« Reply #38 on: July 13 2018, 01:38:42 PM »
Swapping in a new fuel pump once a year is cheap insurance against losing a set of head gaskets...but I'm prolly making to much sense.
« Reply #39 on: July 13 2018, 01:52:22 PM »
With the exception that some pumps may die two weeks after you buy one, you are making good sense!
« Reply #40 on: July 13 2018, 03:33:52 PM »
So we should have a box of 30 used fuel pumps?  :O
« Reply #41 on: July 13 2018, 03:35:02 PM »
Same principle as replacing alky pumps every year or two...insuranc e
« Reply #42 on: July 13 2018, 06:16:38 PM »
Door 1. You can change your fuel pump once a year. It's about a 2 beer job and hundred bucks for a new fuel pump. Door 2. Or, you can go WFO with a pump going weak...and learn how to pull your engine and swap head gaskets and spend a crapload of money. Door 3. You can also leave the engine in, and lean over the fenders to change them and blow your back out.
« Reply #43 on: July 13 2018, 06:20:14 PM »
Maybe we should note we are talking about cars that get raced?
« Reply #44 on: July 13 2018, 06:25:59 PM »
Started a new thread. I'm gonna get some beer...
« Last Edit: July 13 2018, 06:30:34 PM by Scoobum »
