Author Topic: Turbo Tweak GN ECU  (Read 51176 times)
Re: Turbo Tweak GN ECU
« Reply #15 on: July 12 2018, 08:18:07 AM »
If there is no prevision for KR, then I would guess there will be a bunch of people that try to run 30 psi of boost on a 25 psi engine.  Back in the days when I could still claim I could hear, the only time I heard detonation on a TR was immediately followed by a blown engine.
The frequency of detonation in a stock block is reportedly around 6k hertz.  If the factory could monitor it and pull timing, I would think it could be done today as most high performance engines pull timing as soon as they hear knock.
I would also like to track fuel pressure and shut it down when it dropped something like 10% from the boost level.  How many times have I seen people basically running on alky because they did not realize their fuel pump was dying...severa l times.
The easy install and immediate start up is very impressive.  They will sell a bunch of these things. :)
« Reply #16 on: July 12 2018, 08:37:06 AM »
The more stuff they can shove in these boxes to help people save them from themselves...t he better.
« Reply #17 on: July 12 2018, 08:55:10 AM »
The vampire box can see detonation on each cylinder, you would expect this could match it.
« Reply #18 on: July 12 2018, 08:59:25 AM »
Possibly stuff they haven't thot of...but would be willing to incorporate if asked. Jason could start throwing these ideas at them?
You guys with the higher IQ's should start making a list for them?
« Reply #19 on: July 12 2018, 12:47:06 PM »
I found the component test feature this morning.  Can fire individual injectors, drive the IAC and much much more.  Diagnostic heaven!
« Reply #20 on: July 12 2018, 01:03:27 PM »
 :cheers: :cheers:
« Reply #21 on: July 12 2018, 01:11:29 PM »
Looks like a nice upgrade.  I just realized today that my Siemens Low Z injectors are obsolete and no longer made.  That's too bad since everything is finally working so well together...
« Reply #22 on: July 12 2018, 01:45:25 PM »
I may have a set of those....
« Reply #23 on: July 12 2018, 02:52:57 PM »
Couple thoughts.
First, I know you are the guy to make this go. I'm sure Ken will have one soon if he doesn't already.
As far as dash, will a tablet work? Something to slip in front of the giant speedometer.
Next thing comes to mind is the wifi. Is there a way to "lock it down". The statement of "sitting in the stands" worries me about the element of people who might be up to no good . Strong password?
I really like the diagnostic feature. Sounds like a great thing.
Keep us up. This is great.
« Reply #24 on: July 12 2018, 03:25:29 PM »
SWEET!
« Reply #25 on: July 12 2018, 07:05:37 PM »
Been chatting with Bob this afternoon, Looks like there is a way to use the CEL as KR indicator
« Reply #26 on: July 12 2018, 07:58:29 PM »
Do I understand there is no means of pulling timing if the sensor hears knock ala the factory ecm?
« Reply #27 on: July 12 2018, 10:43:59 PM »
Incorrect. The CEL can be used as a visible indicator of knock.  The pulling of timing when knock happens is all tunable
« Reply #28 on: July 12 2018, 10:59:17 PM »
Good...I could not see that not being apart of it...if you can power the cel light, you should be able to hook a buzzer up to it as well...
« Reply #29 on: July 13 2018, 07:55:17 AM »
The boys are honest. Click on, 'Is this required to go fast?' I've never gone to an aftermarket ECU...cuz I know it won't turn my car into a hell ride.
http://www.turbotweak.com/ecugn/
