Author Topic: Poor 60’  (Read 4032 times)
Poor 60’
« on: July 09 2018, 03:53:04 PM »
So I had the Vega at a little track in Victoria wanted to test after my suspension changes.
It’s much straighter and seams to hook well.
I could not get it to 60’ best was a I did was a 1.75 I had the 2 step set at 3400 rpm and saw 10lbs of boost
My suspicion is I flooded it with meth as it starts spraying at 7 psi
How safe am I to dial it back to 10 psi as a turn on point for the meth?
Sent from my iPhone using Tapatalk
Re: Poor 60’
« Reply #1 on: July 09 2018, 04:52:03 PM »
I almost always set the turn on at 10 psi...I think you will be fine
Re: Poor 60’
« Reply #2 on: July 09 2018, 05:35:47 PM »
I would want it at more boost than you are staging with or it is dumping it in while you sit at the line. Can't see that as a good.
Offline reality
Re: Poor 60’
« Reply #3 on: July 09 2018, 05:57:38 PM »
PURPLE wire. I can look it up if you want but it interupts the turn on somehow.
Re: Poor 60’
« Reply #4 on: July 09 2018, 06:50:28 PM »
My buddy Steve with the turbo'd Hayabusa had the same problem with alky. I tuned it one nite at the track a few years back. I kept having him launch it...and I kept turning the alky to come on later and later. I got it bang on when he wheelied it. Didn't expect it and he let out of it. Came down so hard he hit his chest on the tank, knocked the wind out of himself and bruised a couple ribs. Came back to the pits and said he'd  had enuf for the nite. Scoob called him a fukn girl and told him to get back out there.
Offline gusszgs
  • Limited quick brick
Re: Poor 60’
« Reply #5 on: July 09 2018, 07:43:41 PM »
Got mine to come in at around 12 psi from the original 7-8 psi on the controller.... ...seems to work reasonable.
Jim
1987 T Limited
Poor 60’
« Reply #6 on: July 09 2018, 09:43:18 PM »
Hahaha I will try 10 psi
Offline aminga
  • Chicks Dig the Power Bulge
Re: Poor 60’
« Reply #7 on: July 10 2018, 07:50:48 PM »
You don't need it below 15 PSI.  You're OK.  YOu can hook the purple to the 2 step (but I don't remmber if the meth kit takes voltage or a ground to disable the injection)
