Author Topic: Test time! Cam Sensor unplugged  (Read 8695 times)
« on: June 08 2018, 06:58:35 PM »
Will some of you guys that have large injectors do me a favor?  Crank your car up and unplug the cam sensor connector plug.
I have always thought that the car should flip into batch mode and keep right on running as if nothing had really happened.  Not every ones' car does so, however.  Now, John Spina just told me that the car assumes it has stock injectors when it flips over so cars with big injectors may run badly because they are running very rich.
My cars have SD chips and that may be a difference maker.
So go pop the connector and see if you will-if you have larger injectors.
Re: Test time! Cam Sensor unplugged
« Reply #1 on: June 08 2018, 08:38:47 PM »
How big of an injector are we talking?
« Reply #2 on: June 08 2018, 08:39:42 PM »
say 50 psi or bigger...
« Reply #3 on: June 08 2018, 08:54:40 PM »
80's here...but you'll have to wait a couple weeks...
« Reply #4 on: June 08 2018, 10:18:16 PM »
Does it use the analog "programming" of the CALPACK? then it would assume stock.
« Reply #5 on: June 08 2018, 10:19:21 PM »
Crank the fuel pressure way down?
Offline Grumpy
« Reply #6 on: June 08 2018, 11:37:53 PM »
Did that for years with blue tops (36#s). Best was an 11.28 @ 122 in a TTA. Melissa ran 11.4s in a Buick.
« Reply #7 on: June 08 2018, 11:41:20 PM »
Yep, it was common
« Reply #8 on: June 09 2018, 04:18:08 PM »
Guess no one owns a modified version buick in here
« Reply #9 on: June 09 2018, 06:49:03 PM »
Modified, yes!  Running, no.  But very soon.
« Reply #10 on: June 09 2018, 11:29:54 PM »
I'll give it a try when I get back home on wednesday. SD2 on the car
« Last Edit: June 09 2018, 11:43:47 PM by good2win22 »
« Reply #11 on: June 10 2018, 12:03:41 AM »
that would be interesting.  Mine runs okay on SD1
Offline TWild
« Reply #12 on: June 10 2018, 10:33:41 AM »
Hey Steve,
Just for the record...60 lb injectors, 38 psi on the FPR. Runs worse with the cam sensor unplugged. Not running SD.
TW
87' GN, 109 girdled block, Precision 6776, SLIC, Alky, Comp 212/212  flat tappet, stock valve train, TT5.6 Chip, 60lb injectors.
Offline 278CIKILLER
« Reply #13 on: June 10 2018, 11:51:09 AM »
Sorry i couldn't help you Steve, But i sold the car.
« Reply #14 on: June 10 2018, 01:13:51 PM »
Well, hell, Dan!  lol
