Author Topic: MAP sensor wiring  (Read 2575 times)
MAP sensor wiring
« on: May 29 2018, 01:02:50 PM »
So I wired my power logger to the green wire terminal A on C437 like I had it in the white car and nothing, the connector is not connected to anything and I have ran power to terminal F to run the motor, there is no power at the map sensor and I have probed the C437 connector terminal G black and white marked as ground has 5 volts? Nothing at terminal B I jumped the G and B together and got a reading of 20 PSI on the powerlogger? Is it as simple as grounding terminal G?
http://www.gnttype.org/techarea/electrical/GN_C437.jpg
Re: MAP sensor wiring
« Reply #1 on: May 29 2018, 07:51:00 PM »
I'm not sure exactly what you are asking but this is one way to hook a map sensor to PL.     http://www.vortexbuicks-etc.com/PowerLogger.htm
« Reply #2 on: May 29 2018, 08:35:36 PM »
^It's also a much better way.
