Author Topic: discussion on copper gaskets  (Read 9775 times)
« on: May 25 2018, 09:37:18 PM »
I see people claiming to make various gaskets from copper stock. I can't think of any flange on a car that supports a large enough bolt to exert forces that crush a piece of copper. If a very soft copper "gasket" has an embossed/debossed area I could see that flattening to create a seal but otherwise....
Comments?
Re: discussion on copper gaskets
« Reply #1 on: May 26 2018, 10:27:51 AM »
That is pretty much it.  GM MLS exhaust gaskets are embossed for sealing and do a great job.  So, a single layer copper gasket without embossing is going to be hit or miss on its effectiveness. The stock thin 80s flanges are junk.
This is why I have moved to v-bands.  I just put the whole exhaust back on the wagon in under an hour yesterday - leak free.
Offline Lindsayz
  • Newbie
« Reply #2 on: June 26 2018, 01:19:01 AM »
 Can you explain more or recommend a good resource?
« Reply #3 on: June 26 2018, 02:48:16 AM »
yep. www.meatholes.com
« Reply #4 on: June 26 2018, 08:26:42 AM »
classic uptown Earl Brown!
« Reply #5 on: June 26 2018, 01:22:29 PM »
Earl probably get referrals, if not equity...
Offline aminga
  • Chicks Dig the Power Bulge
« Reply #6 on: July 12 2018, 11:22:34 AM »
I've had pretty good success with Copper turbo and header gaskets on the TR
