Author Topic: Timing Cover  (Read 3102 times)
Offline TWild
Timing Cover
« on: May 10 2018, 08:57:18 PM »
OK,
I just installed a new cam and lifters. While I had the front cover off, I did the earlbrown mods. My question is, can the front cover be installed with the cam sensor already inserted into it (with the engine set up at 25 ATDC)?  Ya never know till you ask :chin:
TW
« Last Edit: May 10 2018, 09:03:29 PM by TWild »
87' GN, 109 girdled block, Precision 6776, SLIC, Alky, Comp 212/212  flat tappet, stock valve train, TT5.6 Chip, 60lb injectors.
Re: Timing Cover
« Reply #1 on: May 11 2018, 06:59:43 AM »
I don't think the gears would mesh up with the cam but I guess you could try. I wouldn't do it that way.
Re: Timing Cover
« Reply #2 on: May 11 2018, 07:38:25 AM »
might end up cracking the cover and never get a mesh plus the odds against being installed correctly would be about one in six
Offline TWild
Re: Timing Cover
« Reply #3 on: May 11 2018, 08:56:57 AM »
Thanks Guys,
This is my first time pulling and reinstalling the front cover. I'll just install the cam sensor once the cover is on.
TW
Re: Timing Cover
« Reply #4 on: May 11 2018, 06:35:06 PM »
You can, but it won't be set right.
