The problem with T-bolt clamps is their range of motion is nowhere near that of a worm clamp. In other words, you have to get REALLY specific with the sizes. You have to make sure the bolt doesn't bottom out before full clamping force is applied (and on the other side, being able to start the bolt in the first place).To make it worse they usually size them based on the OD of the solid pipe plus the guesstimated thickness of the coupler. For example a 3" clamp is actually around 3-1/4" in real life ID.When I started doing my MAF pipes and custom up-pipes it was a nightmare to find sizes that actually work in real life. ESP since a turbo bell is bigger than 3" much like an LT1 sensor.Moral of the story, it takes multiple orders to get the size. Even more if you hate a bunch of exposed threads when you tighten them down
Gordy may be on to something. Postulating and drawing imaginary diagrams :While the bands are about the same material and length they loosen off the same when hot but the bolt on theT-Band might lengthen reintroducing an offsetting tension?Hey Mod: a dunce icon but no light bulb icon?
