Author Topic: Parting out another TB  (Read 7491 times)
Offline ss/gn
« on: May 02 2018, 06:43:43 AM »
I have another car I will be taking apart. Let me know if anyone needs anything.
Thanks
Kevin
Re: Parting out another TB
« Reply #1 on: May 02 2018, 01:23:41 PM »
Do you have a black PS mirror base in good shape?
Offline gnonyx
« Reply #2 on: May 02 2018, 04:06:41 PM »
Thanks
Where are you located?
Do you have drive side door?
« Reply #3 on: May 02 2018, 09:53:14 PM »
I'd be interested in a leak free power steering resivior
Offline ss/gn
« Reply #4 on: May 03 2018, 06:22:25 AM »
I am in Kitchener Ontario. I picked the car up last weekend and just had a quick look at it. I will have it on the lift this weekend and know what is good and what's scrap. Drivers door is rotten and will probably be good for its internal parts. I will check in and report back as the project moves forward.
Thanks
Kevin
Offline gnonyx
« Reply #5 on: May 03 2018, 04:53:16 PM »
Thanks
Thanks for the fast reply
