Author Topic: Headlights  (Read 3432 times)
Headlights
« on: April 19 2018, 03:40:21 PM »
Is there a relay somewhere up front for the headlights. Last summer when driving at night ( try to avoid night driving because of the thousands of deer that cant stay off the road) the lights would go out. if I switched the brights/low beams on and off with the turn signal stalk it would make them come back on. Thought maybe there is a relay going bad?? Hope its not the turn signal stalk!!
Offline john robertson
  • I'M INCOGNITO
Re: Headlights
« Reply #1 on: April 23 2018, 07:29:55 PM »
I think your headlight switch is going bad. Try replacing it.
Re: Headlights
« Reply #2 on: May 08 2018, 08:36:59 AM »
What I want to know about this forum is that the new knowledge help me?
If you have a turbo regal I would put the knowledge here up against anywhere else . And there are a great bunch of members. Keep working on your English.
Re: Headlights
« Reply #3 on: May 18 2018, 10:59:41 AM »
Probably a loose ground wire.
Re: Headlights
« Reply #4 on: May 19 2018, 09:40:23 AM »
I think I replaced the headlight switch to fix that problem
