Author Topic: Fuel hangers  (Read 14995 times)
Offline reality
Re: Fuel hangers
« Reply #30 on: April 21 2018, 10:45:14 PM »
YES
Re: Fuel hangers
« Reply #31 on: May 05 2018, 12:21:57 PM »
Picked up my hanger yesterday:
On the float I get 90 ohms down to nothing  so that looks right.
Need to ream out the nipple/flares a bit, pressure side look good, no reduction,
and maybe cut off the reduction in the return line because- Deatchwerks?
Has a 10mm hole for electrics, anyone know what stock was?
I can now ponder if I will make some bracket for the bottom of the pump.
Re: Fuel hangers
« Reply #32 on: May 05 2018, 06:37:05 PM »
I wouldn't bother with a bottom of pump thing. Just hose clamp the pump to the down Hang part and wire it up was the way I am headed next time I drop the tank. Not sure on the electric hole but if I drop the tank or come across the old one I have ill make a measure and try to remember to post about it .
Re: Fuel hangers
« Reply #33 on: May 05 2018, 10:36:13 PM »
Use a paint stick to measure the exact depth on the tank and set the pump depth accordingly.
A pair of stainless hose clamps work just fine.  Just make sure to clock the screw part of the clamp so the pump can drop it.
Re: Fuel hangers
« Reply #34 on: May 09 2018, 01:22:36 PM »
The connector that is under the hood for emptying the fuel tank- that is a suitable connection to trigger a hot wire relay?
Re: Fuel hangers
« Reply #35 on: May 09 2018, 03:43:17 PM »
Yes
Re: Fuel hangers
« Reply #36 on: May 09 2018, 06:26:02 PM »
Thanks  :sw:
Is there some logic I'm missing in placing the relay somewhere else -where it is hard to service or exposed?
Re: Fuel hangers
« Reply #37 on: May 09 2018, 07:30:12 PM »
I suspect that jack can make one up, but, I have always suspected that he makes most things up.
I have built quite a few and I always put it under the hood in line with the other relays.  I use 10 ga wire and concentrate on getting a good ground at the back.
Re: Fuel hangers
« Reply #38 on: May 10 2018, 09:21:16 AM »
You are on fire Steve! :)
Pretty sure I won't spend 30-40 bucks on a new fuel filter bracket either.
Re: Fuel hangers
« Reply #39 on: May 10 2018, 03:00:55 PM »
My hotwire relay is also under the hood like Steve described.
Re: Fuel hangers
« Reply #40 on: October 01 2018, 01:03:40 PM »
This was creative:
Re: Fuel hangers
« Reply #41 on: October 07 2018, 10:31:48 AM »
So here is what I did with the Quantum hangar:
Re: Fuel hangers
« Reply #42 on: October 07 2018, 10:41:31 AM »
I didn't feel like drilling the hole out for a grommet style bulkhead ( given some of the failures I've seen that may be a mistake but I think I addressed them)
Hot side wiring is doubled up and ground is doubled up thru the hangar.
Jack adds a ground by shoving a faston tab under the hangar plate- me no like.I took SS straps and resized them  to create attachment points inside and out.
I really wanted that second clamp on the pump so dremeled a slot. for it
Re: Fuel hangers
« Reply #43 on: October 07 2018, 10:42:36 AM »
Re: Fuel hangers
« Reply #44 on: October 07 2018, 10:43:24 AM »
